Replacing Driver window switch.
Old May 4, 2012 | 03:43 PM
g4ebguy90's Avatar
g4ebguy90
Default Replacing Driver window switch.
OK well, a friend of mine gave me his and unknown if it works. What I am going to do, *PLAN ON* doing is swapping the internals over to mine. They look just screwed in.
Question is, does the thing just pop right out of the door with a flathead. Id really hate to start prying on it and break it.
Thanks. UPDATE ! I replaced the switch and the locks work but the window does not do anything, no noises no nothing. What else could there be???
Do the window motors sometimes crap out????
Old May 5, 2012 | 09:10 AM
Nysc300's Avatar
Nysc300
Maybe your window switch is bad!!
Old May 5, 2012 | 10:39 AM
g4ebguy90's Avatar
g4ebguy90
I swapped it out and didnt change a thing.
Old May 5, 2012 | 12:42 PM
poorsupra's Avatar
poorsupra
Well one day my window switch just stopped. The passenger side would go down with the passenger switch but nothing with the driver. I swapped out my switch, no luck. Turns out where the rubber grommet comes in the door with all the wires had got smashed and a blue(I think) wire had disconnected. Connected it back up and my original switch worked. Hope this helps
Old May 5, 2012 | 02:42 PM
Tommy2JZ's Avatar
Tommy2JZ
my window switches or locks dont work either idk what it can be, when i press the window buttons the lights on the switches dim and i hear like if the motor was trying but had no strength
Old May 5, 2012 | 02:47 PM
g4ebguy90's Avatar
g4ebguy90
I will check the wires by the grommet, cause My motor doesn't do anything no noise no nothing, as if it isnt getting any juice. The passenger is just fine nothing wrong with that.
Old May 5, 2012 | 03:03 PM
Tommy2JZ's Avatar
Tommy2JZ
for me its the same thing with both sides -__-
enio45
RX - 1st Gen (1999-2003)
Jul 25, 2011 08:26 AM
cmarsh
GS - 1st Gen (1993-1997)
Sep 26, 2009 05:32 PM
ehannigan
Jul 25, 2008 10:00 PM
bfigard
Dec 7, 2007 03:34 PM
toykilla
Maintenance
Oct 19, 2006 03:50 PM
