a/c question
Old Jul 21, 2008 | 11:34 AM
horent135's Avatar
horent135
Default a/c question
Yesterday it was a hot day, 100degree, so my car sits outside in the hot sun. I started the car turning the a/c on and windows down, letting the hot air go out. After like 15mins of driving, my a/c blows warm air. Until like 30mins later it start finally getting cold, then after like hour, it actually blow really cold air. Afterwards, i went to the mall for an hour and parked outside. On the way home, it only takes like 15mins to blow cold air again.. Is this a common thing or something bad with my a/c?
btw. I have 95 sc300
Old Jul 21, 2008 | 12:41 PM
redsc400's Avatar
redsc400
that was a pretty common problem in both of my SC's. might want to see if you can get your R12 recharged...or do a R134a retrofit.
Old Aug 2, 2008 | 09:50 PM
sebastian0's Avatar
sebastian0
Anyone done a retrofit on their r12 '93 or earlier GS? I'm looking at doing it. What parts do I need?
Old Aug 3, 2008 | 08:38 AM
Durrr's Avatar
Durrr
CL Folding 25,000
they sell entire kits, but what they consist of is nitrile rubber o-rings/gaskets, PAG oil for your compressor, conversion fittings for the ability to charge R-134. A vacuum pump to remove all non-condensable gasses and to test the system's ability to hold a vacuum will be required, as well as a new dryer/receiver for the refrigerant, and I forget how many pounds of R-134a you need, but you can look that up. If you have all the tools, takes roughly 2 hrs to convert it, not too bad of a job.
CLUM
Oct 29, 2020 09:30 AM
t2014rx
RX - 3rd Gen (2010-2015)
Aug 14, 2014 09:19 AM
mark168
Jul 28, 2014 07:30 AM
ancdmd
Aug 15, 2010 08:18 PM
jholem1
May 8, 2010 01:31 PM
