Going the 1JZ route
Old May 6, 2009 | 01:30 PM
  #121
OneJay's Avatar
OneJay
^^What's the site? Maybe I'll check it out. I'm still waiting on a new harness for the boost controller so I can hook it up, and I'm putting in new dump pipes and down pipe probably next week, so I'm gonna hook up the wideband then too!
Old May 6, 2009 | 05:06 PM
  #122
codetoad's Avatar
codetoad
I'm finishing up my 1jz rebuild and getting ready to swap it in by the end of this month. The only real issue i have yet to decide on, is what I should do with my wiring harness.
I'm running a Blitz ACCESS 1jz ECU, and I was just going to extend the body plugs and relocate it further up in the dash. Is this optimal way to go? I could care less if the ECU sits in the oem location, I just don't want it to be a headache when i go to install electronics later down the road (EMS, or SAFC).
Old May 6, 2009 | 06:03 PM
  #123
$C300's Avatar
$C300
i had the bov leak when i was boosting past like 12-13 psi, id watch the bost drop from like 15psi to 12 somtimes 11, if u do raise the boost change ur bov, just food for thought.
Old May 6, 2009 | 06:12 PM
  #124
SC300_NW's Avatar
SC300_NW
Did you utilize the stock clutch? If so, how is it holding up. Wondering if I need to get a beefier one for my swap.
Old May 6, 2009 | 09:48 PM
  #125
OneJay's Avatar
OneJay
I only extended the body plugs, so my ecu sits behind the glove box somewhat. To wire in my AFC I unplugged the ECU and pulled the wires into the engine bay, and soldered on leads there, then pulled them back into the car with them labled and connected them inside the car.
So far no boost leaks save for the occasional disconnected coupler. We'll see how it holds up after I up the boost though.
The clutch I'm using now is a centerforce stage 1, and it's held up fine so far.
Old May 7, 2009 | 11:05 AM
  #126
SC300_NW's Avatar
SC300_NW
Blown couplers are annoying, run a bead weld on the edges of the piping then spray the inside of the couplers with hair spray before reconnecting. I had hella issues with my FMIC couplers blowing on my previous project, they didn't like 19psi.
Thanks for the info on the clutch. How do you like it? Does if feel similar to stock? I'm trying to get away from a on/off button style clutches.
Old May 7, 2009 | 11:39 AM
  #127
OneJay's Avatar
OneJay
I love the clutch! It feels just a little stiffer than stock, but not any stiffer than some stock cars. The engagement is like stock, but nice and crisp. You can do a nice smooth launch when you want, or you can do a hard launch. The only thing is that if you're driving hard for long periods of time, constantly mashing through the gears, it can heat up pretty quickly and start to give you problems until you let it cool down. Its only happened to me once at a drift day though. Otherwise it's fine for most hard driving.
Old May 7, 2009 | 05:02 PM
  #128
el maestro's Avatar
el maestro
What did you do with the vacuum from the power steering pump?
Where did you run those two vacuum lines?
If you could take a pic that would be awesome....im helping my friend doing the swap right now and wasn't sure about that
Old May 7, 2009 | 06:47 PM
  #129
codetoad's Avatar
codetoad
Any suggestions on simplifying the vacuum lines? or an example picture etc
Old May 7, 2009 | 08:40 PM
  #130
OneJay's Avatar
OneJay
I'll check these out later. I forget where I ran the two lines from the ps pump, but I think one was to the manifold. I don't have a pic of the vacuum lines, but I'm sure there are pics around. Maybe try searching the gallery?
Old May 8, 2009 | 12:26 AM
  #131
el maestro's Avatar
el maestro
Yea because I was looking at the "pic heavy thread" and he has a braided line without the two vacuum ports.
One of my friends vacuum fittings are broken so I wonder where you route the lines if you replace that with a braided line.
Old May 10, 2009 | 10:25 PM
  #132
LMAOMAO's Avatar
LMAOMAO
how is the w58 holding up?
If i could only find a 1jz off of a soarer.
How much harder is it to do a swap using a 1jz from a mk3 supra?
Old May 11, 2009 | 12:01 AM
  #133
OneJay's Avatar
OneJay
The w58 is fine so far. I'm gonna get a 2-step in the next few months hopefully so we'll see how it holds up then.
I haven't done a supra to SC swap, but my friend did an aristo swap and a few things he needed to do that you will need to were:
-harness
-water pump
-downpipe
-intercooler/piping
Old May 11, 2009 | 11:43 AM
  #134
LMAOMAO's Avatar
LMAOMAO
where did you get a soarer 1jz?
thanks by the way
Old May 11, 2009 | 06:20 PM
  #135
OneJay's Avatar
OneJay
I got mine from Jarco, but I heard they stopped importing engines. I think JHOT still does it though.
