alittle budget help please
Old May 15, 2008 | 08:27 AM
want1bad's Avatar
want1bad
Default alittle budget help please
hello all,
New here and wanted to ask a question regarding the 1jz-gte or 2jz-gte swap. I will be selling my truck shortly and will most likely have about 11 grand to play with including the purchase of an sc300. Lets say that i get a car for around 5500-6500 will the remaining 4500 or so be enough for either one of these swaps obviously it wont be a six speed, also keeping the stock turbos. Labor should not be too expensive since my mechanic would love to put one of these together. I have seen on j-hot that they had a 1jz for 2200 and a 2jz for 2700. Any advice would be appreciated!
Old May 15, 2008 | 08:55 AM
chanh55's Avatar
chanh55
You'll probably have to go the 1jz route with only 11K to spend on buying the car and motor + labor.
Old May 15, 2008 | 09:07 AM
bigmalik00's Avatar
bigmalik00
There are few reputable mechanics in NY that will do the swap for cheaper. Why not buy a shell and do a complete build up? You can get the majority of the work done for that price.
Old May 15, 2008 | 10:14 AM
want1bad's Avatar
want1bad
Probably be harder to find a shell than a less than perfect 300. So 1jz seems to be the cheapest route. Is 500rwhp possible with the 1jz without building up the block!!!! I am sure the factory turbos would need to be replaced.
Old May 15, 2008 | 11:04 AM
OneJay's Avatar
OneJay
It is possible with a single turbo set up, but would take a few supporting mods like cams, injectors, ecu, etc. A lot people have done 500hp with on the stock bottom end though. These engines can really take a beating.
Old May 15, 2008 | 01:04 PM
want1bad's Avatar
want1bad
hmmm maybe i would have better luck purchasing a sc with a 1jz swapped already!!!! Although i was told to never buy a swapped car
Old May 15, 2008 | 01:19 PM
One_jZ_SC3's Avatar
One_jZ_SC3
I say you do it yourself..I paid $3k for my SC3 and a total of $2500 on the 1Jz motor w/ auto tranny and labor! If you buy one swapped then you are looking around 9-12K and you dont really know how the swap was put together.....
Old May 15, 2008 | 01:28 PM
aka paco's Avatar
aka paco
man jhot sells there full auto 1jz swaps for $1025 normally, anything extra is shipping, i went and picked mine up last month it was $1096 with tax.
110% complete
I did something similar to you, but i had less $$$ i sold my integra for 6k, and had another 2k from tax return and saving up a little. total 8k
picked up a clean stock 95 SC for $3200, 1jz $1100, new rims with tires $1100, suspesion $700, hids, and maitnence parts for the 1jz swap i have about 8k into full 1jz swapped clean SC...
MJR9191
Feb 12, 2010 05:09 PM
mr_mkelly
Feb 1, 2010 06:57 AM
Mrpickles
Jun 13, 2009 02:17 AM
