map ecu wiring
Old May 10, 2008 | 05:36 PM
traps1971's Avatar
traps1971
Default map ecu wiring
wiring map ecu in my 95 sc400.need to know what the baro pin or color.or what it is
Old May 10, 2008 | 07:12 PM
traps1971's Avatar
traps1971
come on i know some guys on here have in stalled this ecu as of late.any one with what the pin out they used to install.the instructions suck.what pins you guys used to get rid of the maf.
Old May 11, 2008 | 03:38 PM
tritron's Avatar
tritron
I hope this will help you
https://www.clublexus.com/forums/sho...d.php?t=301496
Old May 11, 2008 | 04:22 PM
traps1971's Avatar
traps1971
thanks but i had found that post before.trying to figure out the pins for the blue and green wire that comes of the map ecu.i belive the green wire goes to pin 66 maf just can not figure out the pin for the blue wire,its for vkf reading.sc3/4 should be the same as the maf's are.i know some people on here are using this piggy back.need to know how they wired it
Old May 11, 2008 | 11:18 PM
1sxyrxy's Avatar
1sxyrxy
its either one or the other, you dont use both. your going to be using the blue wire if you are trying to delete the karman vortex. so it looks like pin 66 should be your blue wire
Old May 12, 2008 | 11:47 AM
shonuff53's Avatar
shonuff53
don't know if you have found your answer, but if you email the guys at the mapecu website they respond pretty quick and have these pretty good diagrams that aren't posted on the website that illustrate what mapecu wires go to your ecu wires. just tell them what exact engine/harness your using and boom youve got mail.
Old May 12, 2008 | 03:32 PM
traps1971's Avatar
traps1971
thanks guys.the guys from there site are helping me now
05ls430518
Feb 12, 2018 10:23 AM
scmaluco
Dec 14, 2015 07:15 AM
SCereal
Mar 19, 2010 08:39 AM
DriftGirl
Aug 15, 2007 06:14 PM
Kharizma
Jan 26, 2006 01:25 PM
