Low Coolant Light
Old Apr 22, 2008 | 06:41 PM
SCpwner's Avatar
SCpwner
CL Folding 10,000
Default Low Coolant Light
Hey guys i searched and found a lot of people with the same issues as i am having but no solution. My Coolant is all the way to the top but it's an orange coolant not pink. Also when i lift the sensor cap on top of the coolant reservoir it is a sticky burnt orange. Any ideas of how to fix this? i can drive the car for about a minute before the Indicator light comes on.
Thanks,
SCpwner
Old Apr 22, 2008 | 08:01 PM
Spitfire86's Avatar
Spitfire86
Well toyota coolant is pink..you might have the GM one (it's orange), some people here swear by toyota but idk. There's some long long long debates about fluids if you do a search.
If your fluid level is ok then the sensor could just be dying. I pulled mine out of my SC400 since it is also a common leaking spot. Try reseting your ECU (unplug your battery for a min) and see if it comes back. Keep an eye on your temp guage
Old Apr 23, 2008 | 03:50 PM
SCpwner's Avatar
SCpwner
CL Folding 10,000
How much is it for a new sensor? don't you have to buy a new coolant tank...
Old Apr 23, 2008 | 05:45 PM
blackops's Avatar
blackops
What happened to one of our cars is... the sensor leaked, causing the light to turn on
Old Apr 24, 2008 | 12:02 PM
Spitfire86's Avatar
Spitfire86
The sensor is detachable. I think Aliga has them for like $30 or so.
If you upgrade your whole reservoir they completely delete it in the later models.
Old Nov 20, 2008 | 02:23 PM
whomiked's Avatar
whomiked
What is the name of the sensor on top of the reservoir?
Old Nov 21, 2008 | 08:01 AM
StiCk3's Avatar
StiCk3
It should be fine as long as it is a 50/50 mix of water and ethylene-glycol based coolant. Toyota ones are essentially the same, but off the shelf types that are equivalent work just as well.
afpj
RX - 3rd Gen (2010-2015)
Feb 24, 2018 10:43 PM
DanielDD
Dec 4, 2014 03:55 PM
Ice-Tray
Jun 7, 2009 07:33 PM
Carib
May 1, 2006 07:56 AM
vince00
May 10, 2004 08:26 AM
