mystery part...
Quick question... what is the wire and rubber housing that goes into the top of the coolant reservoir called? i am leaking some reddish fluid from there and want to look for a replacement part but have no idea what it is called...
i have an sc400...
i have an sc400...
but if its leaking through the sensor.. just means its old n needs to be replaced.
get creative and find your own fix. i would just pull the sensor and call it a day. plug the hole with something. SC300's dont have it anyways
all it does is tell you that the reservoir coolant is low. not a big deal. i do a quick check of fluids on my car on weekly basis anyways
so if the hose next to the resevoir cap is leaking coolant (the one that just hangs down and doesnt connect to anything at the bottom) how do you get the extra coolant outta ur resevoir so it stops leaking?
