I got a Goodridge SS brakeline from tirerack and it doesn't fit my 1993 SC300. Was doing the LS bbk today and wasted 1 hour trying to get the brakeline connect to the car brakeline, when i put the stock brakeline back it was so easy fit. Is the 93 SC brakeline connector different from other years?? For those who own a 93 SC with SS brakeline upgrade, where did you guy buy it from?
I have a 93 SC300 w/LS400 brakes also. I got my Goodridge lines from HRPWorld.com (Hoerr Racing) and they fit ... was a bit hard to get it started, but once started, they threaded on like stock.
thanks for the reply, do you remember does the label on the box say for 1993-1998 Supra or it say for Lexus???
I used supra ones from tire rack same as you and mine went on fine.
that what i got, but it seem the the connector doesn't fit the car brakeline, it doesn't screw in at all. Am i the only one having this problem, guess i'm the unluckies ones. 125buck down the drain and i just ordered another set and hope this set works otherwise it would be 250buck down the drain.
you may have to slightly file down the hard line threads on the car. I had to do that when installing my front ss lines from stoptech.
heres a quote from a supraforums post...
"You need to take a file to the threaded fitting on the metal brakeline attached to the car. You'll need to file it around the end where it has mushroomed. This is the threaded fitting, not the actually metal line. The factory puts the fittings on very tight and mushrooms them. Once you file the end down slightly it will fit."
you may have to slightly file down the threads. I had to do that on my ss lines from stoptech.
Same here. The SS line install took triple the time of swapping in the TT brakes and was a real PITA because what you accurately described above.
