newbie needing alil help
Old Mar 2, 2008 | 09:47 AM
COUPLVR93's Avatar
COUPLVR93
Default newbie needing alil help
hey guys new to cl, im doing a interior swap and cant figure out how to remove handbrake lever any help would be great
Old Mar 2, 2008 | 04:14 PM
*hybrid's Avatar
*hybrid
if you're removing the whole lever, there are bolts under the e-brake cover (pics attached). unbolt the 3 bolts shown, and i'm guessing you can just loosen the tension wire til it slides right off.
if you're just removing the handle part, i actually just cut the cover right off, and bolted up an aluminum handle.
Old Mar 2, 2008 | 08:01 PM
COUPLVR93's Avatar
COUPLVR93
thanks i was only going to remove the boot but i guess u cant
Old Mar 2, 2008 | 08:04 PM
JesLet's Avatar
JesLet
Why do you have to remove the whole assembly if your only going to replace the boot?
Is that an ebay ebrake handle? Looks ok but I want one with chrome button.
Old Mar 17, 2008 | 09:14 AM
*hybrid's Avatar
*hybrid
i answered this question, but if you're just removing the boot, it slides right off towards the handle. you may have to cut it to clear your ebrake handle.
Old Mar 17, 2008 | 09:16 AM
*hybrid's Avatar
*hybrid
everything can be found on eBay. mine is a Ractive brand. it has a chrome button. the handle can be carbon, all chrome, or white. i have pieces that i swap out on it. i had to cut it down with a dremel to make it fit correctly.
Old Mar 17, 2008 | 09:46 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
the boot is secured with Velcro. Just grab from the bottom and pull out and up
Old Mar 17, 2008 | 10:40 PM
FormosaSC's Avatar
FormosaSC
yup. just valcro. its the side that is facing you, just pull the boot towards you and then pull the boot off
jwynn
Nov 7, 2016 10:25 PM
Coyotes
Aug 30, 2015 11:51 AM
MEAHT
May 24, 2014 10:50 PM
Ariyanna
Mar 31, 2009 06:00 PM
HKGS300
Oct 21, 2003 03:58 PM
