LS calipers: Where does this retainer go?
Old Feb 28, 2008 | 01:19 PM
JesLet's Avatar
JesLet
Default LS calipers: Where does this retainer go?
I'm trying to figure out where this retainer suppose to be? The one circled in red. Any help will be appreciated.
Attached Thumbnails LS calipers: Where does this retainer go?-ls.jpg
Old Feb 28, 2008 | 03:05 PM
TheCoupe's Avatar
TheCoupe
That goes along the side to hold the pins... some opt not to use them. When I powder coated my calipers the coating didnt allow me to use this style pin. Instead of using a cotter pin I used LS430 pin retainers P/N-47749-50030 ur gonna need 4 in total 2 for each caliper.
Old Feb 28, 2008 | 03:08 PM
JesLet's Avatar
JesLet
So you used LS430 pins? Aren't they different calipers?
Can I just use the retainer above the circled one alone?
TheCoupe's Avatar
TheCoupe
I'm sorry I didnt elaborate... that holds the pins from backing out from the caliper that hold the brake pads in place. It runs along the side of the caliper...
Old Feb 28, 2008 | 03:11 PM
TheCoupe's Avatar
TheCoupe
You could if you wanted to... the pin hole diameter for the caliper pins are universal from any 4-piston Lexus GS/LX/LS. You'll see exactly what I'm talking about when u put them on.
Old Feb 28, 2008 | 03:18 PM
JesLet's Avatar
JesLet
I know the "Y" shape retainer goes outside. What about the one in circled in red, does that goes outside or inside the caliper?
Old Feb 28, 2008 | 03:28 PM
TheCoupe's Avatar
TheCoupe
According to the diagram that i'm looking at it says the the circled one goes on the right hand caliper.
Old Feb 28, 2008 | 04:58 PM
Touge's Avatar
Touge
Jestlet, are those stock pads ?. My ls pads are blue in color behind the pad shim. Hmm.
Old Feb 28, 2008 | 05:46 PM
JesLet's Avatar
JesLet
No, they are Bendix ( ceramic ). I think OEMs are black also. I think you have Project Mu pads.
Old Feb 28, 2008 | 05:50 PM
TheCoupe's Avatar
TheCoupe
The factory ones are blue or gray depends on the year...
Old Feb 28, 2008 | 05:51 PM
JesLet's Avatar
JesLet
My rear TT OEM pads are grey.
drgrant
Mar 31, 2019 12:26 PM
Armitage
May 23, 2017 01:36 PM
lowfunk99
May 17, 2016 03:44 PM
PWidow
GS - 1st Gen (1993-1997)
Oct 28, 2008 05:13 PM
MrG4Life
Suspension and Brakes
15
Oct 27, 2008 09:41 PM
