resetting electronics?
Old Feb 18, 2008 | 07:31 AM
dsevans's Avatar
dsevans
Default resetting electronics?
I am bleeding the TRAC. It seems like the pum operates to bleed on startup, ONLY after the car has sat for a while. 13 hours is what I have so far. If it is started in less time than that it seems like thr TRAC pump knows not to check itself. And once the bleeder valve is closed, the pump won't start again until the 13 hours is up.
Is it possible to reset anything so the car checks each time? I tried disconnecting the negative. The pump still knows.
Thank you.
Darren
dishon22
Oct 15, 2020 10:23 PM
biggywilly
RX - 1st Gen (1999-2003)
Dec 23, 2009 05:18 PM
sorka
Jul 26, 2008 11:47 PM
patyz
SC400 / 300 Classifieds
Nov 23, 2005 12:18 PM
VQT
Oct 21, 2001 10:32 AM
