Please Help, Headlamp problem :(
Old Jan 30, 2002 | 09:20 AM
SDSC300's Avatar
SDSC300
if its just fogging up which one of my lights was doing after I played with it .. you may just need to dry it out and then use some vaseline around the seals where the 3 lights attach. it fixed mine .. the other had a lot of water and I had to open it up and re-seal it, and still fogged until I used the vaseline around the seals ....
Old Jan 31, 2002 | 05:55 AM
The Ikon's Avatar
The Ikon
Originally posted by skininja
Ikon,
You mentioned a broken drainage tube ... I remember when installing my re-done light I noticed a cracked black rubber tube coming out from the back of the light, didn't think much of it. Could my problem just be the cracked drainage tube? Thanks ...
It sure could. Use silicon on the tubing and allow it to dry. Hopefully it may be you remedy.
Damnnchi
Sep 14, 2010 09:43 AM
Druha
Feb 13, 2010 02:42 PM
PinoyBruin
CL of Southern California
Aug 12, 2008 03:38 PM
IS_Dude
IS - 1st Gen (2001-2005)
23
Oct 10, 2002 03:12 AM
