Supra Lower control arm
Old Feb 9, 2008 | 01:17 PM
SC51's Avatar
SC51
Default Supra Lower control arm
My stock passenger side ball joint is shot so i ordered a supra LCA to replace it, my question is do i have to change both to the supra or will i be good?
Old Feb 9, 2008 | 08:03 PM
TheMole's Avatar
TheMole
I'd change both, but thats just me. It should be ok, but you will have a tighter feeling on one side of the suspension. When the other balljoint goes out, then just replace with another supra lca if you don't mind driving around like that for a while. Not sure if it would affect alignment though.
Old Feb 11, 2008 | 02:26 PM
SC51's Avatar
SC51
ok ya i was just wondering cuz they look identical and id rather buy springs because the ds one is new, only other question is, is a shop gunna need to remove this r they pressed in?? or can they be hammered out?
Thanks
Old Feb 11, 2008 | 02:54 PM
dwebb99's Avatar
dwebb99
I would change them both to supra lca. The lca supra arms are firmer than the lexus ones(and cheaper as we all know) and your front end suspension is just going to feel weird until you get a matched pair of lca's. I would not be in the habit of mismatching these. Just sell your good used lexus one and get the other side supra lca.
Old Feb 11, 2008 | 03:35 PM
TheMole's Avatar
TheMole
Yea you won't get the full potential of your lowering springs with worn lca bushings/balljoints.
Old Feb 12, 2008 | 10:06 AM
SC51's Avatar
SC51
ok sounds good guys ill do that, and now my only question is does a shop need to press these out?
Old Feb 12, 2008 | 10:11 AM
TheMole's Avatar
TheMole
The whole assembly comes out and will be much easier if the car is on a lift. If you are just replacing the bushings then those will have to be pressed out/in.
Old Feb 21, 2008 | 04:33 AM
1jhazzard's Avatar
1jhazzard
hey guys, not trying to hi-jack but i have a question on almost the same topic. so here it is? are the supra OEM LCA the only ones that will work on the sc300 or will aftermarket ones such as cusco and tein's supra lcs work as well? thanks.
Old Feb 21, 2008 | 05:22 AM
xx69xx's Avatar
xx69xx
If the supra LCA work on the SC then im sure Aftermarket ones for the supra should go on to the SC as well. I could be wrong.
Old Feb 21, 2008 | 07:40 AM
97RSPSCTT's Avatar
97RSPSCTT
I just replaced my lower lca w/ MKIVs and I love em, imo I would get oem. They are very durable and going to give you a much tighter feel. Do it right the first time and change both. Be carefull with aftermarket cheap crap too. Cheers
Old Feb 21, 2008 | 08:43 AM
1jhazzard's Avatar
1jhazzard
thanks for the replys, i wold have thought that if a supra oem would work then so would an aftermarket but intellexual only said oem so i wasnt sure. as for cheapo ones i would most likely go with a JIC, Cusco, TEIN if i went after market.
Old Feb 21, 2008 | 08:36 PM
SCoupe's Avatar
SCoupe
CL Folding 25,000
Originally Posted by 1jhazzard
thanks for the replys, i wold have thought that if a supra oem would work then so would an aftermarket...JIC, Cusco, TEIN if i went after market.
Aftermarket LCA's ?? I didn't know those co's made them.
anu7898
May 31, 2013 06:05 AM
ScDoinIt
Sep 10, 2011 04:55 PM
bio3m
Feb 7, 2008 12:53 PM
97-SC300
Apr 20, 2007 11:30 AM
