You get 2 wheels spinning when its equal weight on each, but a little difference on one side and then the wheels starts spinning a furious 1 wheel peel.
the door tag lists if the car was equipped with lsd or not. I didnt check the door tags on the SCs that have done two wheel burnouts nor did I open the diff to check.
Next time I see the cars I will make sure they were non-LSD.
dont waste your time. if the diff is stock its guaranteed to be an open diff.
heres a link to my car doing a burnout.
that was back in the day when it was open diff. it starts off with one wheel and then the other one breaks loose and keeps going.
It doesn't matter. Put plainly and simply, it was never offered.
Both mine spin from a stop in a strait line I leave two Identical marks so I guess I'm lucky (My 92 sc400 would only ever spin one) but when you give it gas in a corner it is painfully clear that it is not an LSD.
