Squealing Noise when STOPPED and applying Brakes
Old Jan 15, 2008 | 06:47 AM
LesMan's Avatar
LesMan
Default Squealing Noise when STOPPED and applying Brakes
I'm guessing this is some sort of vacuum problem... but I haven't been able to nail down the source or solution.
When I'm at a stop, with the car running, I can press down further on my brake pedal and hear this whining / squealing / high pitched noise. The noise gets progressively louder and then fainter as I press the pedal down towards the floor. There is no noise when I let off the brake pedal - and rolling down the road.
This noise seems to come and go. Sometimes it's gone all together. That's what makes it so hard to diagnose. Can't isolate it to hot / cold weather or engine temp.
This IS NOT a brake rotor / brake caliper issue.
This noise happens at a FULL STOP.
Any suggestions??
My sincere thanks in advance - this forum is awesome!!
Old Jan 15, 2008 | 11:19 AM
TheMole's Avatar
TheMole
Maybe something to do with your ABS system?
Old Jan 16, 2008 | 03:40 AM
Durrr's Avatar
Durrr
CL Folding 25,000
the way the vacuum booster works is that it has a diaphragm inside that helps move the piston to compress the fluid when you push the brakes, therefore moving brake fluid etc etc. If this has a small tear in it, it would cause that noise I THINK you're describing.
corradoMR2
Jun 13, 2020 01:23 PM
Chilton88
Hybrid Technology
Sep 7, 2019 09:42 AM
gfietz
Oct 23, 2014 12:16 AM
JohnnySpag
Suspension and Brakes
Aug 30, 2006 07:40 PM
Lisa_LX
Jun 19, 2004 01:15 PM
