Power Steering Pump Question
Old Jan 12, 2008 | 02:00 PM
miraluna's Avatar
miraluna
Default Power Steering Pump Question
Mine doesn't work when my car just starts... drive for 10 min and turn off the engine and restart, it works...
This is funny but this is what it does.... it started since yesterday... I went to see mechanic and it works fine... my mechanic wants me to leave the car overnight with him so that he would know what the problem would be...
my other question would be : would 01-05 IS 300 power steering pump be a direct fit for my 92 SC300???
Thank you all in advance
Old Jan 12, 2008 | 02:08 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
PS pump goes on an engine, engine has a forum.
Moved
Old Jan 13, 2008 | 08:07 AM
miraluna's Avatar
miraluna
anyone knows if IS300 PS pump fits into SC300??
Old Jan 13, 2008 | 04:46 PM
TheMole's Avatar
TheMole
Probably doubtful.
Old Jan 13, 2008 | 09:40 PM
TURBO819's Avatar
TURBO819
Default IS300 PS pump?
They look the same from what I remember. I will take a look later on today to let you know for sure if they are the same.
Old Jan 13, 2008 | 09:47 PM
5sp_jzz30's Avatar
5sp_jzz30
i think i have a spare PS pump off a 95 auto sc300. ill check and get back at you with that.
Old Jan 14, 2008 | 07:35 PM
TURBO819's Avatar
TURBO819
I took a look and they do look the same. The pressure feed tube looks to be bent at a different angle. That should not be a problem because you would be reinstalling the pressure feed tube from the SC300.
Old Jan 14, 2008 | 07:40 PM
shern's Avatar
shern
Try the following in order:
1) Check your fluid level, fill if low
2) Clean the filters in the a) reservoir and b) selenoid on the rack and flush system
3) Replace power steering pump
Here is some insight into my ordeal:
https://www.clublexus.com/forums/sho...d.php?t=319113
Old Jan 14, 2008 | 07:49 PM
miraluna's Avatar
miraluna
Thanks, Shern
I will do it that order!!!
1st step is done!!!
Thanks again
Old Jan 14, 2008 | 07:55 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
check that valve that comes off the bottom that has 2 nipples, one that runs to your intake manifold and the other runs through block to your actual intake. sometimes they an crack easily but usually make you have full power steering all the time, at least mine was cracked. am i allowed to say nipples?
Old Jan 14, 2008 | 10:25 PM
miraluna's Avatar
miraluna
I just found out that mine makes whinning noise at start up...
Well, I already order used IS300 PS pump...
Will update soon!!! once I get the pump...
Old Jan 23, 2008 | 09:25 AM
miraluna's Avatar
miraluna
IS300 PS pump fits perfectly and now mine works great!!!
Old Jan 23, 2008 | 09:34 AM
FormosaSC's Avatar
FormosaSC
you should change ur fluids just in case, check for leaks because its a comon problem for sc300/400.
suck the fluids out with a pump and a straw, then replace it. i do this everytime i change my engine oil.
Old Jan 23, 2008 | 10:18 AM
shern's Avatar
shern
I blew my lines out with air. It made a big *** mess at the end of the line, but I knew I had everything out!
hidavi
Jun 11, 2016 10:36 AM
betojuice
Oct 31, 2013 03:39 AM
BrittonJ85
Apr 28, 2010 10:39 AM
Tymboo
Nov 13, 2006 08:44 PM
andrew_A_3
Oct 13, 2006 01:35 AM
