Stock Stereo ?
Old Jan 26, 2002 | 06:25 AM
SC3BOY's Avatar
SC3BOY
Default Stock Stereo ?
I have replaced my stock stereo with an aftermarket unit. I had the standard Pioneer system. I removed the tape/tuner unit out of the center console. The odd thing is is that I have noticed my climate control doesnt work right. It seems like it has been since I removed the radio. I know that they are right next to each other, but other than that I see no correlation between the two. By not working right I mean that the fans are either on FULL heat or they are on MAX cold. If I have the setting on anything other than MAX cold it spits heat. Like it practically melts my face off heat. Plus the sensor must not be working right because it doesnt change the settings with varying temperatures. Plus the AC doesnt really work, it is just kind of cold. This could just be because the car is getting old though (1993). Has anyone else experienced this or anthing like this? I am just missing something silly? You guys are the only ones I have to turn to. Please help, its driving me nuts!
Old Jan 26, 2002 | 09:27 PM
London Bill's Avatar
London Bill
I recall there a couple of Earth connections (black cables with round connections) bolted to the hi-fi mounting frame, if they are not re-attached to a good earth it could upset the Air-Con controls.
Or possibly you have dislodged one of the plugs from the rear of the Air-Con unit or the control switch.
Old Jan 27, 2002 | 05:04 AM
933005spd's Avatar
933005spd
Default yeah, the plugs, yeah
I would expect the plugs on the back of the ac console are not seated. This problem occured on a install I did with a 400 coupe, we had to remove it again, plugged in and voila....
Old Jan 27, 2002 | 06:19 AM
SC3BOY's Avatar
SC3BOY
I wish it was that simple. I have checked the plugs, they are all good. But his idea of a ground type of wire on the stock radio, I will look into. Thanks.
ainwarhol
IS - 1st Gen (2001-2005)
Sep 14, 2017 09:32 AM
LuxuryGS3
Dec 7, 2016 07:43 AM
2JZGTE SC
Oct 16, 2009 08:27 AM
juan b
Nov 19, 2008 06:19 PM
theomms
Feb 20, 2003 10:04 AM
