SC400 top performance?
Old Dec 16, 2007 | 01:53 AM
reckless88's Avatar
reckless88
Default SC400 top performance?
ive been looking at the specs of the 95 sc400 and comparing it to tho the 97+
the older sc's specs say hp is at 250 but the 97+ is at 290 hp also i saw a chart that listed add ons from year to year and it looks like the newer ones have VVT-i cam shafts and im trying to figure out witch parts i could order and have installed that are for a 98 or 99 but going in to a 96 for performance gain?
Old Dec 16, 2007 | 10:21 AM
over40driv's Avatar
over40driv
Yah, the 98- up have the 290 hp with vvti, from what I understand the vvti addition isnt that easy to add. There are other options, such as headers, torque converter, turbo. Or you could sell your 95 and buy a 98 up.
Old Dec 16, 2007 | 11:12 PM
red04r1's Avatar
red04r1
its like trying to add vtec to a non vtec engine.. going to cost less swapping the motor then it would be trying to change over heads, cams, ecu... .. ..
Old Dec 17, 2007 | 03:46 PM
KC95SC400's Avatar
KC95SC400
I agree. Keep in mind it's more than just bolting on camshafts. The heads are probably different and you would need the 98 / 99 ECU to control the vvti. The 96 ECU wouldn't know it's there to control.
KC
Old Dec 19, 2007 | 12:32 PM
ihiryu's Avatar
ihiryu
Why can't we just swap the heads? Does it work on oil pressure like vtec does? On honda setups, they block off a hole in the head for oil, then run a line (like an turbo feed line) to the head.
I don't see why we can't attempt to try the same thing.
Old Dec 19, 2007 | 01:40 PM
KC95SC400's Avatar
KC95SC400
Heck, if your that determined, go for it. I'm sure you'd need an ECU regardless. I also think it may be cheaper to find a wrecked car to take the whole motor and ECU out of.
Check Lextreme.com, I'm pretty sure the topic has been discussed over there.
KC`
MartelJF
May 7, 2014 09:36 AM
tuninghaus
Sep 4, 2011 04:35 AM
mikevanle
SC400 / 300 Classifieds
Jun 9, 2005 04:29 AM
MadMaxSC400
Jun 1, 2003 11:32 AM
Boost'n
Mar 25, 2002 07:00 PM
