I forgot , maybe 4 inches. I will check when I get home. I probably use a straight bolt on the other side for the shift ****. Without the crank, shifter will sit on SC cupholder
Do you think there will be a clearance issue with the old shifter and base in the trans tunnel?
It's a s13 nothing I can't fix with a hammer and/or a torch. Ha ha kiddy stuff with 500 whp.
This guy removed the factory short shifter assembly and used the r154's shifter arm in the trans and got the supra shifter welded on the solstice base for 60 bucks at a fabricator.
http://www.supramania.com/forums/sho...stice-Solution
