throttle body compatiblity issue?
Old Nov 28, 2007 | 07:22 PM
dumdumgreg's Avatar
dumdumgreg
Default throttle body compatiblity issue?
Anyone know if the odb2 (1997) SC300 throttle body
will work on a odb1 car??
They look the same (almost; the brackets for the semi wheel that the gas pedal cable attaches to is a bit different, but functions the same)
same number of hoses going in/out
Thanks
Last edited by dumdumgreg; Nov 28, 2007 at 11:25 PM. Reason: specified year of part
Old Nov 28, 2007 | 09:05 PM
Lexus082's Avatar
Lexus082
I am not sure. The obd1 throttle body is for 92-95. I am not sure if the obd2 would work on an obd1 car. Sorry I can't give any more help.
Old Nov 28, 2007 | 11:24 PM
dumdumgreg's Avatar
dumdumgreg
normally I wouldn't figure they are the same, but visually comparing both side by side, it looks the same
same Idle Air Control motor, TPS, wires, hoses, etc....
(only thing that I would guess, is maybe the IAC or TPS repsond to different voltage signals from a odb2 ecu? )
I think I'm gonna try it, I'll update the post when I do
(unless someone posts with a definite answer that they are not)
thanks
Old Nov 28, 2007 | 11:28 PM
soarinhigh's Avatar
soarinhigh
not to be dumb but, why?
Old Nov 28, 2007 | 11:50 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Old Nov 29, 2007 | 01:34 PM
dumdumgreg's Avatar
dumdumgreg
I busted the idle adjustment screw, it snapped off
so I'm changing out the TB
I can prolly extract the bust adjustment screw of the TB after I get it off the cra, but there is no way to xtract it while on the car, not enough room to work
Old Dec 4, 2007 | 10:43 AM
CantSeeMe's Avatar
CantSeeMe
thanks
http://www.supraforums.com/forum/sho...8&postcount=34
bighead222
May 16, 2011 03:02 PM
NEbiker10
Mar 22, 2011 09:54 PM
LEXMICK
Oct 30, 2009 01:34 AM
1siksc
SC400 / 300 Classifieds
Feb 1, 2008 11:33 PM
BigDave
Apr 1, 2005 02:34 AM
