Front end noise MAYBE ?
Old Nov 15, 2007 | 02:48 AM
planejane's Avatar
planejane
Default Front end noise MAYBE ?
Remember putting cards on your bicycle spokes to create noise?. Thats what I have between 20 and 40 mph. Noise goes away after 40. It was time for shocks and brakes. I've replaced the shocks and the brakes. Everything is within limits. New water pump and belt too. The noise is still there. I have michelin pilots for the tires. 1993 Sc400 with 165,00 miles. I've managed to fix everything else from this forum. Thanks in advance....Jane
Old Nov 15, 2007 | 09:03 AM
djl's Avatar
djl
Check the drive shaft center support bearing. It is encapsulated in rubber and will deteriorate with age.
Good luck.
Old Nov 16, 2007 | 10:13 PM
Lexus082's Avatar
Lexus082
Is it coming from the front suspension? Does the noise change when you apply the brakes?
Old Nov 16, 2007 | 10:55 PM
bangdangvn's Avatar
bangdangvn
could it be from wheel bearings?
Old Nov 17, 2007 | 07:23 AM
planejane's Avatar
planejane
Sorry for the delay... Had to go out of town. The noise does not stop with the brakes. It is related to the speed. I'll check out the drive shaft this week. I've got acess to a lift. Doesn't sound like wheel bearings. My experience is failure at high speeds for bearing noise. Of course airplanes are different than cars.Thanks Jane
I8ABMR
IS F (2008-2014)
Oct 3, 2014 07:38 PM
diverchris
Jun 5, 2013 08:22 AM
Ca1vN
Suspension and Brakes
Sep 23, 2011 03:48 PM
IluvS600
IS - 1st Gen (2001-2005)
Apr 20, 2010 09:54 AM
xknowonex
Maintenance
Jan 31, 2008 09:34 PM
