TRD Hi-Performance Brake Kit
Well, I can tell you that the calipers are very nice. In fact, they're LS430 calipers that Toyota paints TRD on. All aluminum, 1 pce. fronts. See what size wheel the 430 uses stock and you'll know what size you need to clear them. I know 18's will clear, but I'm not sure about 17's.
and its not size (16" could fit, used on the LS400s) its the disk fitment, ie-if ur running an aftermarket wheel, you want something with a "High Disk" or "BBK-Friendly" fitment.
^These be TT brakes yo
Ya, those are. Those aren't what I'm talking about though. Why anyone would pay that for that kit is beyond me. Also, they're being advertised as aluminum calipers, when in fact they're are half aluminum and half steel.
I'm talking about the TRD kit for the Supra TT, among other cars, that uses rebadged LS430 calipers that are full aluminum calipers.
LS430 brakes look like this (minus the paint and decal of course)
also, stole this from AndrewW over at My.is
Originally Posted by AndrewW
The LS430 calipers have an interference issue that the conventional mount to radial mount adapter can't be made to fit. (the radial bolts need to be in the same location as the conventional bolts to attach the bracket) With larger rotors this wouldn't be an issue, however the LS430 caliper is designed for a 315mm rotor. I have also confirmed that the TRD brake kit using LS430 calipers is a myth, they aren't the same at all. Although the TRD is radially mounted, and is monobloc, that is where the similarities end. The TRD caliper is wider which sits inboard far enough to not interfere with the conventional mounting locations, and is designed for a 323mm rotor, not a 315. I have compared the TRD dimensions from their drawing to the LS430 calipers and they are NOT the same. However, they are a gorgeous 4pot/2pot aluminum monobloc caliper, and are reasonably priced, they just won't fit IS300 uprights. Consequently I ordered my front and rear 4 piston Rotora brake kit. Perhaps someone knows someone with an LS, or has an LS, or has another project that these could be used for.
Thanks,
Andrew Wojteczko,
Auto Analyser Racing
Thanks,
Andrew Wojteczko,
sorry to bring back old thread.
I got good offers from local wrecking yard on Front LS430 brake calipers, has anybody tried to install this on SC300? I like to know if this is applicable or not.
I know that supra turbo and LS400 calipers bolt on
Where is this kit from and more importantly, how much is it? Those are rebadged Stoptech calipers/rotors ... wondering if they're cheaper than a Stoptech-branded set ...
FuMoFFuTT
Nov 28, 2009 12:13 AM
jvsc300
Jan 29, 2009 07:34 PM
supradean
Feb 26, 2007 12:21 PM
Stage3
Wheels, Tires & Brakes Forum
13
Mar 26, 2004 06:50 PM
