DIY, Tutorials, How-To collection (MERGED THREADS)
Old Nov 8, 2010 | 01:11 PM
  #31
Novoken's Avatar
Novoken
Originally Posted by outlaw0209
https://www.clublexus.com/forums/is-...-required.html
Here's something to try. Worked for me. Still need to do my window trim. It isn't specific to window trim, but you should get a good idea.
nice!! ill get a can after work
Old Nov 22, 2010 | 11:23 PM
  #32
blacksc4's Avatar
blacksc4
easy headlight mods for clearer lights and bttr cut off
https://www.clublexus.com/forums/sc-...y-sorta-p.html
Old Jan 18, 2011 | 07:16 PM
  #33
Gaza's Avatar
Gaza
Post 1993 SC300 Fuel pump removal!
1) Disconnect battery
2) (not necessary) But feel free to remove the EFI (Electronic Fuel Injector Relay) located under the hood. Driver side larger fuse box (no4.)
3 )Remove the lower seat by pulling up on the front part & pull out.
4) You will then see 3 mounting bolts at the base of the upper portion of the rear seat,remove these bolts with a 12mm socket & push up & remove upper half.
5)You will then see a cover with 8 bolts remove & the fuel pump is now within reach.
6)Now detach rubber fuel line (clamp) from the steel section of the fuel line.
7)Their will be three nuts (10 mm) exposed remove them & pull out bracket which will house the fuel pump.
Old Feb 13, 2011 | 01:29 AM
  #34
abounly's Avatar
abounly
https://www.clublexus.com/forums/sc-...moval-diy.html
Fender removal step by step with lots of pictures!
Old Feb 13, 2011 | 06:52 AM
  #35
spoolxexo's Avatar
spoolxexo
JZ swap Consultation thread.
https://www.clublexus.com/forums/per...ml#post6076071
Old Mar 12, 2011 | 01:28 PM
  #36
Belement's Avatar
Belement
SC300 W58 Clutch Writeup
https://www.clublexus.com/forums/per...56k-no-no.html
Old Apr 22, 2011 | 09:30 AM
  #37
Lexatron's Avatar
Lexatron
My Contribution to DIY!
DIY Broken Remote/Valet key repair
Old May 10, 2011 | 02:14 PM
  #38
FatBrian81's Avatar
FatBrian81
Every sc400 owner should read this thread: https://www.clublexus.com/forums/sc-...on-issues.html
Old May 23, 2011 | 04:56 PM
  #39
kill3st's Avatar
kill3st
I found a DIY guide for replacing power antenna.
here ya go!!!
http://www.lexls.com/tutorials/audio/powerantenna.html
Old May 23, 2011 | 10:20 PM
  #40
raine's Avatar
raine
My contributions so far:
HOW-TO: SC300/SC400 Install Aftermarket Head Unit, OEM Speakers and Sub Working! (super thread step-by-step w/pics)
HOW TO: SC300/SC400 Double-DIN Stereo Install + Metra Mod for Double-DIN Head Units (super thread step-by-step w/pics)
Raine's Garage Guides: Spring Install How-To (step-by-step w/pics)
Raine's Garage Guides: Wheel Studs / Spacers How-To (step-by-step w/pics)
Old Jul 1, 2011 | 02:25 PM
  #41
MattStarr's Avatar
MattStarr
How to remove that annoying open sunroof reminder
https://www.clublexus.com/forums/sc-...-reminder.html
Old Jul 15, 2011 | 05:05 PM
  #42
JJAUTOWERK's Avatar
JJAUTOWERK
Default Any write ups for changing the water pump?
Was wondering if theres any diy threads for changing the water pump
Old Jul 21, 2011 | 12:02 AM
  #43
Luxor's Avatar
Luxor
Default SC300 Power Steering Hose Replacement
https://www.clublexus.com/forums/per...ring-hose.html
Old Jul 27, 2011 | 10:44 PM
  #44
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Power steering valve rebuild/block
https://www.clublexus.com/forums/per...s-one-out.html
Heater core control valve substitute/replacement
https://www.clublexus.com/forums/per...rol-valve.html
Popping door hinge
https://www.clublexus.com/forums/sc-...7-seconds.html
Door panel fix
https://www.clublexus.com/forums/sc-...el-repair.html
Convert corner lights into fogs
https://www.clublexus.com/forums/sc-...og-lights.html
Shifter Led conversion technique
https://www.clublexus.com/forums/sc-...e-shifter.html
Everything to know about the cluster and climate unit
https://www.clublexus.com/forums/sc-...-clusters.html
A/C compressor removal/installation
https://www.clublexus.com/forums/per...tallation.html
Seafoam 101
https://www.clublexus.com/forums/per...k-in-here.html
Engine, tranny mounts V/S center driveshaft bearing
https://www.clublexus.com/forums/per...r-bearing.html
TPS sensor changes
https://www.clublexus.com/forums/per...ps-sensor.html
idling issues
https://www.clublexus.com/forums/per...look-here.html
Old Aug 31, 2011 | 07:45 PM
  #45
2jznosht's Avatar
2jznosht
https://www.clublexus.com/forums/per...c300-pics.html
Found a starter install...
