1jz vacuum ?
Im finishing up my swap (1j r154 soarer) and there are two vacuum lines Im not so sure about. the one on the inboard upper side of the intake manifold that comes off of a what seems to be a check valve or something not really quite sure. As well as one on the outboard side that comes off of the throttle body to a hard line to a soft line that t's under the manifold and the other part just hangs up by the metal bracket on the outboard side of the manifold.
I tried to be very descriptive because my camera does not work with crappy vista, Im still trying to get a map sensor so im guessing that one of these lines goes to it but im not sure. I've searched the web and found a diagram with part numbers but I still dont know what numbers are what components. If you can help me it would be greatly appreciated. also from what I gather can I actually use the usdm 2j map sensor for my swap?
thanks in advance..
thanks in advance..
this is the diagram Im referring to, I dont see the map sensor part number on here... hmmm
http://i3.photobucket.com/albums/y55/Flea420/vac1.jpg
kanukem
Dec 16, 2015 07:48 AM
