Safety Neutral Switch wiring
Old Oct 30, 2007 | 01:40 PM
Rexn30's Avatar
Rexn30
Default Safety Neutral Switch wiring
Ok since no one has a pic of what to do.. I'm showing a picture of the plugs that went to the stock 1jz tranny. Please circle the PLUG that you use. And please tell me what to do. And hopefully if this post works you can sticky it. Haha
Old Oct 30, 2007 | 03:18 PM
Rexn30's Avatar
Rexn30
If know one knows how just tell me how to run a push button /shrug I need this car running asap =/
Old Oct 30, 2007 | 03:22 PM
DominicAN's Avatar
DominicAN
...the car is 5 speed but swap is auto correct?
Old Oct 30, 2007 | 03:23 PM
Rexn30's Avatar
Rexn30
5spd tranny and auto ecu
Old Oct 30, 2007 | 03:50 PM
DominicAN's Avatar
DominicAN
is the tranny on the car?...would have been easier to do the harness stuff while it was all out of the car...
the only plug we needed help with is the reverse light one as they arent compatible but on the rest i do recall we had to cut/soder one plug onto the auto 1j harness to complete the connection
Old Oct 30, 2007 | 04:09 PM
Rexn30's Avatar
Rexn30
Hmm, I don't think you get what im doing here.
Old Oct 31, 2007 | 09:35 PM
shlounek's Avatar
shlounek
Wats up Rexn30, I got your PM but I was busy so I couldnt reply.
Basically the wire you have running in the picture what you will need to do is plug one of them into the reverse signal, and the other also plugs into the tranny into the speed sensor. The other wires you can simply ignore.
As for the Neutral safety switch, you just need to ground the NSW wire that is plugging into the ECU, the way I did it was just cut the NSW wire and wired it to the A/T indicator switch which thinks the car is in neutral. n But grounding it is prolly easier.
As for the the start switch, Find your starter signal wire and run it into the car, you can either wire it to the STA2 under the steering wheel, just get voltage tester and find out which wire sends 12V when its on the start position. Or just create a switch make run 2 wires 12 volt from battery and wire to starter signal wire.
Hope it helps.
Old Nov 1, 2007 | 12:10 AM
Rexn30's Avatar
Rexn30
Well, I went to pepboys today and bought a push start button kit. Not positive but it looks like you will do the wiring just to the ignition and not tought the starter or anything... Will this work?
Old Nov 1, 2007 | 04:35 AM
cruzinbill's Avatar
cruzinbill
Yah, that should i was thinking of doing the same thing. Run all the wires where is says to run them, except the starter one. Run it to the starter spade connector. Here is a somewhat helpful link showing where to hook the wires up on a relay for it. its on a mustang but the idea is there. http://www.latemodelrestoration.com/...LRS-11572K.pdf
hsokhi
Aug 16, 2015 06:34 AM
A32Boost
Nov 2, 2012 10:40 AM
mktbully
Jun 13, 2011 11:26 AM
StiCk3
Nov 8, 2010 04:32 PM
lex1997
SC400 / 300 Classifieds
Mar 14, 2006 03:19 PM
