what is EGR?
Oct 17, 2007 | 03:31 PM
what is EGR?
My check engine lights when on and so did the traction off. I pulled the code (67) and it's the EGR. What is that and how do i fix it.
Every little info is helpful
thanks!!!!
Oct 17, 2007 | 04:06 PM
Exhaust gas recirculation, just run a search and you'll find plenty of info on it.
Oct 17, 2007 | 04:59 PM
well..i did but don't know what the usual problem is. Do I have to change the valve or other stuff. Anyone experience the same?
Oct 17, 2007 | 05:15 PM
usually the valve is all stopped up with carbon or the lines connected to it. Just clean it up and it'll proly go away.
Oct 18, 2007 | 07:17 AM
Rex is right, but remember...pulling a code does not always mean 1 particular thing is wrong. You're getting an EGR code and that could be due to one or more of at least 6 different things.
Oct 18, 2007 | 11:31 AM
Oct 18, 2007 | 12:02 PM
I removed my entire EGR system and made my own block off plates.
I still have
not gotten a check engine light
Oct 18, 2007 | 01:41 PM
Quote:
Originally Posted by
Blk97SC300
I still have
btw where did you mount your map ecu
Oct 18, 2007 | 05:28 PM
lexforlife
right by the ECU (passenger area, under glovebox, where their feet would usually go kinda).
lexusLO
Nov 16, 2011 09:46 AM
campoida
15
May 7, 2009 01:36 PM
phollero
GS - 1st Gen (1993-1997)
May 3, 2007 02:27 PM
Racerhoze
17
Mar 20, 2004 11:37 PM
svptwobe
May 30, 2002 05:54 AM
