o2 sensor mounting question
Old Oct 2, 2007 | 02:23 PM
Gunnar's Avatar
Gunnar
Default o2 sensor mounting question
I searched and didn't find an answer, though maybe I'm just not using the right terms. I just dug into the o2 sensors last night and found that they're in a little plate that bolts onto the header, and not a screw in like I'm accustomed to. Is there a plate that has threads in it so I would be able to screw in a o2 sensor and then bolt it to the header?
Old Oct 2, 2007 | 02:51 PM
Gunnar's Avatar
Gunnar
Headers like the MVP/Xerd don't have that same mounting provision, they just screw in. I thought I remembered reading that there were o2 sensors where they would screw out of that plate and be able to screw into a header like that...I'm looking for just that plate to put a wideband into it.
Old Oct 2, 2007 | 03:52 PM
Gunnar's Avatar
Gunnar
In case anybody else searches for this somewhere down the road, I picked up a "flanged Toyota o2 sensor bung" off EBay for $9, looked to be exactly what I was looking for.
Old Oct 3, 2007 | 11:06 AM
VW_Vanagon's Avatar
VW_Vanagon
Another thing I was thinking is that I have a wide band with a 5 volt output I was wondering if I could just remove the stock O2s and replace them with a wideband signal?
Old Oct 3, 2007 | 12:54 PM
Gunnar's Avatar
Gunnar
You can, read up in your wideband's instructions about it.
Old Oct 4, 2007 | 06:15 AM
bangdangvn's Avatar
bangdangvn
where did you pick up the sensors? is it one kind for both up and downstream? (i.e. with flange)
RedlineAZ
IS F (2008-2014)
Jul 15, 2014 09:09 AM
Lmood
IS F (2008-2014)
Feb 19, 2014 08:57 AM
TRM09
Jul 7, 2010 10:17 AM
Sup2jzgte
Apr 1, 2009 05:04 PM
messysc
Apr 30, 2003 05:28 PM
