Can anyone verify that the ECU for the SC300 and Supra NA are the same?
Need to make sure before ordering aftermarket unit.
Yes every pin out that I've seen shows that they are the same.. wire colors are the same and go into the same spots, etc...
if you're unsure go check out Apexi's website; it has a lot of docs with ECU pinouts; look for the 2jz-ge motors
