Speedometer accuracy and LSD
Old Jan 16, 2008 | 04:25 PM
  #31
Blk97SC300's Avatar
Blk97SC300
Originally Posted by DIrEctQL
It wouldn't be stupit. You'll have to get a solution for all the problems you'll come to when you go turbo. AEM EMS is the solution. It also comes with a base map for stock car so you can drive it around. Althrough you can find a cheaper way to fix the problem you will not have to hack your harness or much else.
I have the YellowBox and it works great. My speedo is corrected just fine.
OLT- the Yellowbox fixed this problem in no time- nothing complicated at all. I didn't need to do anything to the "obd2 system" either. Power, ground, and cutting the speedo wire directly at the speedo sensor on the tranny.
https://www.clublexus.com/forums/sho...d.php?t=312511
scroll toward the end of the thread and you'll see some useful info about correcting the speedo with the YellowBox.
Hope this helps
Old Jan 16, 2008 | 05:12 PM
  #32
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
how much are those things.
you could probably build one yourself.
Its probably just a pulse width modulator.
sounds complicated, but one of the first things we built back in school.
Old Jan 16, 2008 | 07:51 PM
  #33
Blk97SC300's Avatar
Blk97SC300
i think it was around $90 or $100.
SCVito
May 6, 2022 06:13 PM
XxPainxX
Sep 2, 2011 10:48 PM
moto696
Mar 14, 2011 02:10 PM
Konnan101
SC400 / 300 Classifieds
Mar 3, 2008 09:57 AM
LasVegasGS
Oct 22, 2005 12:18 AM
