Coil over help
http://www.tein.com/edfc.html
EDFC only adjusts the rebound settings of the shocks. EDFC is not compatible with the Basics. To get a set that works with EDFC, you'll be about double your budget (after factoring in the cost of the EDFC unit)
I was looking into these springs but i cant find to much info.I thought i can go with these espiler springs since they drop about 2 inches and save up for some hard core coil overs later on
For $800, you could have put together a pretty damn kick *** shock/spring combo OR have the cheapest coilovers on the market that have yielded mixed reviews from those who have purchased them on this very forum.
I would rather have a kick *** ride with dampening adjustment on a fixed drop than a very average ride with no dampening adjustment with drop flexibility.
Once you set the Basics to height, you are not going to adjust the ride anyways. And, if you do, you will be screwing with your alignment. Rather, choosing the right drop springs would offer the drop you are looking for with a significantly better ride.
I made a similar decision. I had about $1000 for suspension, and I chose to stay under budget with top of the line springs than squeak by with marginal coilovers.
However, if ride height is your primary concern, the Basics should serve you just fine.
