112 octane question
Old Dec 21, 2001 | 10:19 PM
abutler696's Avatar
abutler696
Default 112 octane question
Would 112 octane gas help out an N/A engine? and if so...how much? thanks...
Old Dec 22, 2001 | 12:37 AM
MadMaxSC400's Avatar
MadMaxSC400
Hot Rod did a dyno test using tuned SBC motors (350's), changing timing and seeing the differences in how the engine benefits. I think the biggest gain was from jacking timing way up and using 115, that was worth 20 hp from 87 octane baseline. Don't bet on it being enough of a factor, especially for 5 bucks a gallon and 100 ci less. The motor simply won't take much advantage of it- the guys with turbos however can use it to reduce knocking in their cars when the boost is turned up. They also showed octane boosters as being detrimental to performance in some circumstances, and gains of only 2-3 hp in others. I would be interested in seeing what my motor would do on the dyno with say, 110 octane unleaded race gas, but I'd be suprised if it made more than 5 hp.
Old Dec 22, 2001 | 06:56 AM
SC300T's Avatar
SC300T
As mentioned, you have to advance timing to take advantage of the higher octane... Advancing the timing raises cylinder pressure slightly which makes more power. I would guess with lots of tweaking on a timing controller like an Apexi ITC, you could probably get 20hp or so. On a turbo SC300 you can get as much as 100hp extra . The difference is in the cylinder pressure... A Normally Aspirated engine can only build up so much pressure at 10:1. Turbo's effective compression ratio under boost can go 15:1 18:1, 20:1 , who knows.... That's where you need higher octane to resist the mixture from spontaneously exploding instead of buring after the spark is introduced.
If you could somehow raise the compression ratio on the SC300 to 13:1 (different pistons?), you'd see a big difference when running 112 octane. Problem is the car would run and idle poorly on normal gasoline.
Zosopage
Feb 1, 2017 08:32 AM
Emilaman
Maintenance
12
Mar 19, 2011 07:18 PM
Toysrme
May 18, 2003 05:20 PM
CDALTON
Nov 10, 2002 07:40 PM
Mike
Performance
Sep 16, 2002 09:57 PM
