Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#4921
Repost since i got no response
I am looking at a set of Linea Corse rims that are:
LC818 5X114.3 19x8.5F +30 73 Hub Bore
LC818 5x114.3 19x10R +38 73 Hub Bore
4 Concentric Hub Rings will be included 73>60.1
My question is I am not a fan of the stretched tire look at all...I am looking to run a square setup..
Would I be able to fit a 235/245 up front and a 265/75 out back....I am would not have a problem doing a roll and it will be setting on a pair BC coilover....
The bigger tires the better...
What do you guys think?
#4922
#4923
Quick wheel and tire question...I'm about to jump on a killer deal for some saleen wheels and tires. The specs are as follows. For an uncool person like me who plans to keep the car at stock ride height will I need to roll the rear fenders ar all?
front: rim size 18x9; offset +24; tire size 255/35/18
rear: rim size 18x10; offset +22; tire size 265/35/18
#4924
18x9" 22+ in the rear on 265/35/18.
I understand from the first post 10" 38+ is maximum on the rear before any fender mods, etc, is required. But if my math is correct, dealing with .12" (3mm) difference.... a few hair over. Can that be walked away on or should I roll the fender to accomodate that 3mm?
I'm not wanting to stance, etc etc etc whatever with that super camber stuff....
My options are only 18x9 22+ or 50+. Or if I go 18x10, the wheels is only available at 15+.
#4925
Those are pretty weak offsets (as opposed to aggressive) Your fronts are going to be SUPER sunk, and rears will sit in about 13-15mm from fender. Run a 285 in the rear, you've got the room! I'm running a 10" wide in the rear +25 with a 275 and it sits flush. my fronts are 8.5" +25, and I have a 15mm spacer on there, and they are still sunk.....
#4927
Sure, if you go for a 10 or 15mm spacer then you'll be fine. A 10mm spacer will give you an effective offset of 40mm which is OK and a 15mm spacer will give you an effective offset of 35mm which is more ideal for an 8" wheel. Are all four wheels 18x8?
#4928
yes its a square set up. 15mm is about what I was looking for didn't want to go much further than that.
Thanks!
#4929
I have some wheels that are off a mustang 18x8F +24and 18x10R +45. I'm not looking for a crazy aggressive stance. I'll be lowered about 1.5in, I don't wanna do fender mods or rubbing if I can avoid it. What proper tire setup should I be looking into?
#4930
Came across these searching for some Varrstoens ES222. Anyone got some advice if these offsets would work on 97 Sc? lowered on coilovers/ have front/ rear fenders rolled
Front Size : 19x9.5 Front Offset : +22
Rear Size : 19x11 Rear Offset : +25
If you anyone has tried this please let me know... post pics if you have similar set up
#4931
#4932
The 11" rears +25 look amazing. You WILL need to stretch the tire, and do a minor pull. There is a picture on here in the 20" wheel thread with a flat black SC with 20x11" +25 in the rear and 20x10" +15 up front. Looks great! If you're only going to go 9.5" up front, you might want to look into the +12/+15 (I can't remember which offset they come in) so that the front will be closer to the same fitment as the rear
#4933
#4934
#4935
This was before I pulled my quarter panels, it is just rolled flat in these pictures. (I'm on air btw)
