SUPRA rear subframe into a SC?? WILL it WORK?
You can use just the rear subframe mounts from the Supra to use the sway bars. Replacing the entire subframe is an entirely different story. To the OP, if you do this, please document and take pictures as you go.
From: Sideways on the Yellow Brick Road! < Thats KS!
I believe "Supra DR" has done it and I also am preparing to give it a try.
EDIT: Wrong! I just read it again. He put the MKIV Subframe in his SC and that is what I am going to do.
I was swaping the complete MKIV because I need the six speed diff, six speed axles, and brakes. Seems easier to bolt the whole assembly in.
Well please let me know if it works!! I havent bought mine yet. I heard the 6 speed subframe has some extra bracing.
Yes..........
Of couse it's a upgrade. HD diff, axles, brake calipers, rotors, sway bar,
everything.
The only changes I made was the connectors on the ABS sensors &
swapped the parking brake cables.
I'll look around for pics.
everything.
