Check Engine Light - What was your Problem?
Old May 30, 2007 | 06:41 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
Originally Posted by contentryd
came back from advance auto...scanned with OBDII ...two problems came up:
P0441
EVAP Emission
Control System
Purge Flow Fault
P0446
EVAP Emission
Control System
Vent Circuit Malfunction
anybody happen to know what these mean?
yup...I just don't know how the Lexus EVAP system works... gimme a few and I'll get you some info...
Old May 30, 2007 | 07:59 PM
mitsuguy's Avatar
mitsuguy
well, hell... Mitchell has the full diagnostic procedure for this, but they are in the middle of an update right now...
here's the heading... I'll post the full diag procedure as soon as it's up and running...
Old May 30, 2007 | 08:31 PM
al4nek's Avatar
al4nek
I got my sc300 about a month ago.
I got code 71, EGR System Malfunction, what should i check/ replace?
It has aftermarket exhaust if it matters.
Old May 30, 2007 | 08:58 PM
mitsuguy's Avatar
mitsuguy
ok, here's the rest...
Old May 30, 2007 | 09:02 PM
mitsuguy's Avatar
mitsuguy
there ya are...
Old May 30, 2007 | 10:05 PM
contentryd's Avatar
contentryd
thanks alot mitsuguy...ill have to go check this out...i have alldata but havent checked up on it yet...alldata dont really tell you what to do though ..willl report back
Old May 31, 2007 | 05:35 AM
mitsuguy's Avatar
mitsuguy
alldata sucks
I've used it too... not a fan
Old May 31, 2007 | 07:03 AM
mitsuguy's Avatar
mitsuguy
71: EGR Gas Temperature Less Than Predetermined Level During EGR Control
this is one of those that isn't going to hurt ANYTHING... you can just leave it alone - it means either the temp sensor is bad or there isn't enough EGR flow to heat up the temp sensor...
but, if you want to fix it, here is what you do:
Old May 31, 2007 | 10:20 AM
contentryd's Avatar
contentryd
is that mitchell on demand or mitchell ultramate you have?
Old May 31, 2007 | 11:00 AM
mitsuguy's Avatar
mitsuguy
ondemand5...
Old May 31, 2007 | 03:23 PM
al4nek's Avatar
al4nek
mitsuguy- thank you for reply, i will try to fix it maybe in the future , propably to pass emission test.
Old Jun 2, 2007 | 07:38 PM
contentryd's Avatar
contentryd
sadly..i cannot find the EVAP VSV...where is it located?
Old Jun 13, 2007 | 02:33 AM
contentryd's Avatar
contentryd
bump....does anyone know where the EVAP VSV is located??
thanks!
Old Jun 19, 2007 | 05:51 PM
contentryd's Avatar
contentryd
bump bumpp
Old May 23, 2011 | 05:59 PM
Salil022's Avatar
Salil022
bumping this old thread as i have same codes on my 99 SC300
p0441 & p0446
