r154 help
Old May 9, 2007 | 05:03 PM
craaaazzy's Avatar
craaaazzy
Default r154 help
okay guys,
i need someone who has done the mkiii r154 swap to help confirm some things.
-is the shifter rod straight or have a slight "s" bend on it?
-will a w58 shifter rod fit the r154?
thanks in advance.
Old May 10, 2007 | 06:17 AM
sc250tt's Avatar
sc250tt
its alot more than just bending something you have to extend the shifter and change bell housing to a jz series .search is your friend.
Old May 10, 2007 | 09:18 AM
craaaazzy's Avatar
craaaazzy
i know all about the extension, 1jz bellhousing, mkiii fly, etc.
my question is pertaining to the shifter rod. does the w58 shifter rod fit the r154? if not, is the stock shifter rod from an r154 straight or s shaped.
Old May 10, 2007 | 02:16 PM
Teflon Don's Avatar
Teflon Don
the stock shifter from the R154 from mk3supturbo is s shaped.
Old May 10, 2007 | 07:38 PM
craaaazzy's Avatar
craaaazzy
thanks teflon. guess i need to find someone local so i can take a look at the shifter and compare.
BuffNStuff
Oct 22, 2014 11:08 AM
babillarac
SC400 / 300 Classifieds
Aug 10, 2012 07:16 PM
suprakidxx
Feb 7, 2012 12:01 PM
navazsc3
Mar 7, 2011 03:23 PM
