92 SC400 horn button wiring Q?
hey guys, did a quick search, didnt notice anything on the issue
i installed a horn-button-less steering wheel on the ol' SC400.
I want to run an horn button somewhere on the dash (not sure where yet)
the question... which wires are the horn wires at the harness you unplug from the OEM wheel???
thanks in advance!
thanks in advance!
there's a big white connector that meets under the steering colum, unplug it and use a paper clip (with one end grounded/touching metal) or just use a probe and poke around the connector (not the the half connected to the wheel, use the side that would logically connect to the horn) untill you find the one that goes "beep" That's your maginc pin.
CRuby
Jun 6, 2010 11:28 AM
Lexologist
Jul 21, 2005 01:28 PM
