Ride Height off.. HELP ASAP!
Old Nov 29, 2001 | 04:08 PM
mjames08's Avatar
mjames08
Default Ride Height off.. HELP ASAP!
I have a 93 SC400 and it feels (and looks) like the driver side is 1-1.5 inches lower than the passenger side... What parts beside the springs could be causing this to happen? Please respond ASAP, I am bringing the car in to have a new set of Eibach's installed on Monday, and maybe I could get all of this done at once.. Thanks in advance for your help!
Mark James
Old Nov 30, 2001 | 04:43 AM
Keith13b's Avatar
Keith13b
Springs most likely aren't "seated" right in the perch. There are rubber tops on the springs that are form fitted to accept the spring. If you dont "fit" the spring into it, it will make the car unbalanced. Check it out. Simple to fix if thats the problem.
Keith
Old Nov 30, 2001 | 07:11 AM
abutler696's Avatar
abutler696
Keith.....I just installed some Eibach's the other day(so far only on the back) and whenever I hit a bump the back of the car does a "da clunk" noise. It sounds like a big thing a metal is flying up then landing hard. I looked under my car last night and on the left side the spring isn't locked in place....at least the bottom isn't....its like an inch and a half away. Could this be the problem?
Old Nov 30, 2001 | 09:03 AM
mjames08's Avatar
mjames08
Default Thanks
Thanks Keith, I will check that out.. Is there anything else that could cause the problem? Struts?
horent135
Nov 22, 2010 10:39 PM
gman44116
Suspension and Brakes
Nov 23, 2009 12:26 PM
EGainer
Aug 7, 2002 08:18 AM
