headlight help
Old Apr 12, 2007 | 01:58 PM
dartdoc1's Avatar
dartdoc1
Default headlight help
My passenger side headlight went out about a month ago so I finally bought a replacement set but the passenger's side still would not work and now my drivers side doesnt work. Do the plugs go bad or is there a fuse anywhere to check my daytime running lights still work as well as my fog lights is there a way to check for voltage or do the plugs just go bad any help would be appreciated.
Old Apr 12, 2007 | 03:43 PM
aznxenon's Avatar
aznxenon
when my driver side headlight fuse blew my fog lights didnt work....
Old Apr 12, 2007 | 09:57 PM
DY3VERSITY's Avatar
DY3VERSITY
Check your fuses in the fuse box. Its located right behind the battery.
Old Apr 13, 2007 | 03:40 PM
dartdoc1's Avatar
dartdoc1
Did that today all were o.k. I was able to get the drivers side to work seemed to be a loose connection still no luck w/ the passenger's side will do voltage and ohm test when I get a chance bulb looked good even switched them still no light
malikb
Apr 8, 2014 01:15 PM
Es300Lover
Feb 20, 2013 10:11 PM
rerose
Apr 30, 2012 05:30 PM
my_shaldan
GS - 1st Gen (1993-1997)
Apr 7, 2008 11:18 PM
