Crank pulley bolt- how do I remove this thing?
Three things that will work:
1. High pressure compressor...A 1/2 in gun, impact socket, and 175-200psi will usually do the job with no heat.
2. if that doesnt work, I use this tool from matco: https://www.matcotools.com/Catalog/t...#51516....This can be a one man job on the stand with the breaker bar on the floor, and use a big pipe as others have mentioned. This has only failed me once out of 30+ 2J crank pulley bolts.
3. The end all be all. If this tool doesnt do it, get a new shortblock
You need to "shock" the bolt to free it, and snap on has a burly *** tool for doing so: The site is not responding, so i cant find the link. basically it is a big bar that attaches to an impact socket of your choice, and you use a burly hammet to hit the top of it and force the bolt down. Kinda like a manual impact driver for the bolt. This tool has broken the hardest bolts our shop has ever encountered.
Thats only half the battle too, you will need a puller to get the pulley off once the bolt is off. Good luck, hope this helps!
Josh@FSM
You need to "shock" the bolt to free it, and snap on has a burly *** tool for doing so: The site is not responding, so i cant find the link. basically it is a big bar that attaches to an impact socket of your choice, and you use a burly hammet to hit the top of it and force the bolt down. Kinda like a manual impact driver for the bolt. This tool has broken the hardest bolts our shop has ever encountered. Thats only half the battle too, you will need a puller to get the pulley off once the bolt is off. Good luck, hope this helps!
Josh@FSM
Used a little creativity.. and got the son of a b1tch off
I wedged a metal extension between a hole in the flex plate (not using the auto tranny any more, so I had no use for that piece of scrap metal). The ratchet extension was wedged between the block and the engine stand. With two people holding the block/engine stand, my friend basically hung on the retardely large pipe- and broke the bolt free
Then after a beer, I realized I had only conquered half the battle. the damn crank pulley is stuck now. What an adventure..
I have a few good gear pullers at home. I'll try to use one of them tommorrow on the crank pulley. Hopefully it works..
Allen
Then after a beer, I realized I had only conquered half the battle. the damn crank pulley is stuck now. What an adventure..I have a few good gear pullers at home. I'll try to use one of them tommorrow on the crank pulley. Hopefully it works..
Allen
.well now you know the backyard mechanic way
ta1972
Oct 25, 2007 09:15 AM
