Front end noise???
Old Feb 17, 2007 | 06:00 PM
skpark70's Avatar
skpark70
Default Front end noise???
The front end noise appear when turning...
I did some searching and some says its the power steering fluid is low and mine is full and some says LCA bushings and I tend to agree.. My SC3 has 120k miles thus far. (I recently went NA-t and don't remember noise was there before)
If it is the LCA bushing problem should I just replace the bushes or get Supra tt arms??
I have heard some say installing bushes could go upto $500 and new tt arms are $400.
Need your expert feedbacks..
Thanks in advance.
Old Feb 19, 2007 | 07:05 AM
aftv's Avatar
aftv
Default front end noise
What kind of noise..? scrapping..popping or what..?
Old Feb 19, 2007 | 08:26 AM
MJHSC400's Avatar
MJHSC400
Hard to say without a description of the noise. Does it happen when you turn the wheel even if you're sitting still? Is it a thud, clunk, pop??
Daizen bushes are the way to go if your balljoints are still nice and tight, which should be the case if it's an accident free car..
$100 rebuilds the LCA's , upper and lower actually, all 8 bushings, and includes the upper sleeves, reuse your lower inner sleeves, though you only need to do the lowers to correct the problem if it is bushings.
Old Feb 19, 2007 | 01:11 PM
skpark70's Avatar
skpark70
Its combination of popping and clunk... Yes it does that when steering even sitting still.
Old Feb 19, 2007 | 03:03 PM
MJHSC400's Avatar
MJHSC400
When you brake, or hit a speed bump, does it happen? Also, is it more pronounced from one side than the other?
I'm bankin on LCA bushings--
Neophyte2b
Oct 19, 2009 12:07 AM
RI-Lex
Suspension and Brakes
May 4, 2009 01:15 PM
maaloxx
Jul 18, 2005 06:33 AM
