Supra/SC Control arms?
Old Jan 28, 2002 | 04:22 PM
cupete's Avatar
cupete
One of the reason why I wanted to upgrade the sway bars is that my car started to wander around on freeways after I upgraded my tires/rims (235/45/17 and 255/40/17) I was thinking that upgrading the sway bars will fix the problem along with replacing my old shocks.
Replacing sway bars aren't that hard? What about shocks? Any instructions on how to change shocks at home?
Thanks,
Peter~
Old Jan 29, 2002 | 05:13 PM
amati5's Avatar
amati5
Peter,
I don't think what you described is body roll. It's because you have wider tires with lower walls in the front. The wider tires give more contact with road and the lower walls give more feed back. This combination overall gives you a more sensitive steering and you have to pay more attention on the freeway. When you drive your wider front tires over an uneven cement, you feel it pulls to one side more than normal because of the wider contact. And the lower walls make it even more sensitve. This is why most of sport car have narrow tires in the front. Lower walls is better since you get more feed back but try to stay with the same width in the front like 225x50x17. I have 245x45x17 in the front and it pulls like crazy. Sometime i thought the wheels were loose. I will change to 225 next time.
I doubt if stiffer sway bars will help you with this problem. But they will help your car from rolling to one side around the curves/corners for sure.
Old Jan 29, 2002 | 09:01 PM
cupete's Avatar
cupete
Thanks for the input, I was going to put 225/45/17 in front with Yokohama db tires, I currently have 235/45/17 Yokohama A520 and someone in GS forum said Yokohama Db tires will solve the cars wandering on freeways/streets.
Peter~
Old Jan 30, 2002 | 04:28 PM
SCV8's Avatar
SCV8
Something else to check out,possibly,would be the alignment specs for the Supra,since that car came with wider tires.
Old Jan 30, 2002 | 04:42 PM
cupete's Avatar
cupete
Also, check your tire pressure.
I checked it last night after reading stuff related to wandering vehicle from GS400 forum. My tire pressure was 28!!! Damn, for some reason, I put the tire pressure to 38 all around. To my surprise, my car do not wander anymore but it's way bumpier than before.
This led me to the question on aftermarket tires/rims. What's the right tire pressure? I always thought 35 was the right pressure, however, with 35 tire pressure, my car would wander on freeways and streets. What's the difference between 35 and 38 pressure? It seems like increasing the pressure up to 38 has stopped my car from wandering. But is it safe to drive on tires with 38 pressure?
Peter
Old Jan 31, 2002 | 04:41 PM
SCV8's Avatar
SCV8
Good point,there's a conversion available through Firestone tire shops(and probably elsewhere)that gives tire pressure ratings for alternative tires/rims.
Old Feb 7, 2002 | 08:20 PM
cupete's Avatar
cupete
SCV8,
Someone wants to sell me his Supra TT sway bars (front and rear) for $65 plus shipping. Is this good price? Once I get these, I will try to install them myself, if I have any problems, I will contact you. =)
Peter~
Old Feb 8, 2002 | 06:11 PM
SCV8's Avatar
SCV8
I wouldn't waste my on getting the front ,as I believe it's the same as on our cars,but the rear ois an improvement for certain.
Be sure and get the rear subframe bushings so as to be able and mount the thing on your car.
Old Feb 10, 2002 | 03:35 PM
cupete's Avatar
cupete
Thanks for SCV8,
However, I would want to change the front one as well since this one will be alot newer than mine.
Peter~
Old Feb 12, 2002 | 09:16 AM
mrKophee's Avatar
mrKophee
Default The control arms
I'm stuck replacing my front lower contol arms because of lack of bushings. Lexus arms run $470 in my area. Supra ones run $290. According to my research 93+ TT supra ones will fit correctly and they are a little stiffer. I would like to confirm this before I rip my car apart to find my parts don't fit. Also will SC shocks fit on these I wanted to get a new set of Tokicos and just keep the OEM springs. One more thing would upper control arms from a supra fit al well? Thanks.
Old Feb 12, 2002 | 04:46 PM
SCV8's Avatar
SCV8
There's a junkyard in Lynwood,named Nix99(425.743.2881) that has a Supra with a damaged front end there that you'd possibly be able and look at for comparison.I was just talking to Don there last week about bushing differences/interchangeability,since they are available for the '97 cars,but he didn't have anything that new.
I'm still looking at that option before I make my own,but that's what had to be done in the past,so it can be done.
I have actual Supra shocks on my SC,so that part is fine,I'd just want to check the swaybar mountings;I know the rear control arms are slightly different.When I mounted a rear bar from the SupraTT on my SC,I had to use the swaybar links from the SC for it to work correctly.
Good luck.
Soloist
Jan 9, 2012 02:42 AM
tuninghaus
Dec 9, 2009 07:00 AM
nefariousd
Jun 29, 2009 09:49 AM
NoLongerA13bFan
Jan 14, 2008 10:54 PM
SDSC300
Jul 8, 2002 07:53 PM
