DANG Stupid thing happened
Old Jan 31, 2007 | 05:20 PM
nasc300's Avatar
nasc300
Default DANG Stupid thing happened
So, I finally got the VPC and AFR wired up and everything seemed fine. 15 psi and loving it. I made a left turn out of a gas station and the engine dies. It won't turn over and thier is no electrical power. I pop the hood and found the battery hold down strap "welded" to the positive battery pole. The electrical system is shorted out. Where should I start looking, all fuses and relays are good, yet not even the starter, windows gauges, radio or anything else works. Do you think the problem is with the ignition switch?
Old Jan 31, 2007 | 05:39 PM
Rising_Sun's Avatar
Rising_Sun
HAve you checked the big main fuses? They are in the bottom row of the fuse box next to the battery.
Old Jan 31, 2007 | 05:42 PM
96sc3's Avatar
96sc3
Have you tried push starting?
Old Jan 31, 2007 | 06:03 PM
nasc300's Avatar
nasc300
Yep
It's auto
Old Feb 1, 2007 | 01:30 PM
nasc300's Avatar
nasc300
any help welcome
Old Feb 1, 2007 | 01:37 PM
cal9126's Avatar
cal9126
have you tried jumping the car.....sounds like the battery is shot if no light acc or anything is coming on...and double check the fuses...they are sometimes hard to tell if there blown or not....
Old Feb 3, 2007 | 09:41 AM
nasc300's Avatar
nasc300
All fuses ans relays under the hood in the main black box are good. Also the fuses and relays on drivers side kick panel are good.
Is there another fuse box?
I tested the starter and Alternator and they are both good.
The one problem I found was the voltage between the battery + and the body which is about 8 volts, while voltage between + and - battery poles is 12.25 volts as well as the voltage between battery + and engine block is 12.25 volts.
When I try to place a ground between the engine and the body (frame) I get a spark.
Why a spark between two negatives?
Why the low voltage between battery and body (frame).
Where should I continue to look?
Old Feb 3, 2007 | 01:37 PM
mattsmall's Avatar
mattsmall
Registered User
check the ground that should fix it when i had a weak ground and i put another wire on the ground it would spark.
Old Feb 3, 2007 | 03:21 PM
nasc300's Avatar
nasc300
Thanks got it started. The ground between the bell housing and the frame at the bottom of the car was burnt through.
stwork
Oct 18, 2018 08:42 PM
Tishbish
GS - 1st Gen (1993-1997)
Mar 22, 2016 02:33 PM
DannySz
14
Jul 31, 2013 12:23 PM
PMC75
Feb 8, 2013 06:30 PM
SC400Drive
Feb 11, 2010 12:04 PM
