R154 shifter extension mod writeup w/ PICS !
Subscribe
Feb 13, 2011 | 04:03 PM
  #31
bellhousing, extender, speed sensor, maybe clutch, lines, mounts, cross member ect.
Reply 0
Feb 13, 2011 | 06:11 PM
  #32
shoot me a PM
Reply 0
Feb 14, 2011 | 05:40 AM
  #33
pm sent to you
Reply 0
Mar 1, 2011 | 01:56 PM
  #34
How many inches did you extend the arm from stock?
Reply 0
Mar 1, 2011 | 04:21 PM
  #35
Quote: How many inches did you extend the arm from stock?
huh? arm? you mean the shifter housing?
Reply 0
Mar 1, 2011 | 05:26 PM
  #36
Arm, lever its all the same. This one
R154 shifter extension mod writeup w/ PICS !-dsc00802.jpg
Reply 0
Mar 1, 2011 | 05:28 PM
  #37
depends on the vehicle its going in and which shifter you are using. this was the very first one i made and it was about 2 inches too long.
Reply 0
Mar 1, 2011 | 05:31 PM
  #38
Its going into a 93 sc300 factory 5sp. I am just trying to save myself the hassel of putting the trans in place 4-5 times to get the correct size. A write up with mesurments I can not find.
Reply 0
Mar 1, 2011 | 07:39 PM
  #39
if you are using the swan neck, then i would extend it 2 3/4" if you are using a short throw then i would extend it 4 inches or so. I went from auto so i had to make a new cutout since the auto is in a different location.
Reply 0
Mar 2, 2011 | 04:57 AM
  #40
Quote:
Supraman24 if you are using the swan neck, then i would extend it 2 3/4" if you are using a short throw then i would extend it 4 inches or so. I went from auto so i had to make a new cutout since the auto is in a different location.
So if you extend it 4inches or so wouldn't that put it rite in the middle of the auto hole?
Reply 0
Mar 2, 2011 | 05:07 AM
  #41
Quote: So if you extend it 4inches or so wouldn't that put it rite in the middle of the auto hole?
yeah, pretty close
Reply 0
Mar 3, 2011 | 07:42 PM
  #42
What about for a manual hole? 5-6 inches?
Reply 0
Mar 3, 2011 | 09:39 PM
  #43
The manual hole is closer to the dash so i think that would be 2 3/4"
Reply 0
May 7, 2012 | 08:04 PM
  #44
Cool info!
Reply 0
Apr 27, 2013 | 11:37 PM
  #45
Was this for a gs3 swap?
Reply 0
