heater fix???
Old Jan 18, 2007 | 06:54 AM
datsetup's Avatar
datsetup
Default heater fix???
man its been gettn real cold here in cali and last winter my heater was working no prob... this winter its blowing nothing but cold air is there a simple fix?? please give me input
Old Jan 18, 2007 | 09:17 AM
Jewcano's Avatar
Jewcano
No Sir, I Don't Like It
CL Folding 1,000,000
You havent searched man, most common thing, which has happened to mine is the solenoid under the hood that connects to the heater valve is dead. Another problem could be the hose that connects to it might have come off.
Old Jan 18, 2007 | 11:07 AM
datsetup's Avatar
datsetup
which hose where are they located??
Old Jan 18, 2007 | 11:15 AM
Jewcano's Avatar
Jewcano
Stole this from another thread about the same problem:
Heres the link to that Thread, searching does a body good : Here
Old Jan 18, 2007 | 11:41 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
Or the most simple and common problem.................low coolant!
Old Jan 18, 2007 | 05:14 PM
sc3dreamz's Avatar
sc3dreamz
I'm still stuck on my heater problem. I replaced the hcv with one from Ali(member on the bords). I replaced the radiator b/c it was bad, I replaced the thermostat for the just in case, I replaced the radiator cap b/c it looked old and still no heat. My last thought is the heater core but I have no leaks, although it could be clogged up. Now I cant get the d@mn dash off. All the bolts I can think of are off, wire harnesses undone. It will move like its lose but I think I'm missing a bolt or two. Anyone have a diagram or picture of the bolts that need to be undone? Sorry to hijack your thread but I'm cold my d@mn self. 20 degrees this morning, 10 the other day.
Old Jan 18, 2007 | 05:26 PM
skjohnson's Avatar
skjohnson
good thing i live in FL! lol
but i have the same problem too! and its not like IM cold, cause im from NY so it doesnt matter until its like 20-30's but my girlfriend is always complaining...
so...yeah...lol but i remember i went to a shop and they said that they would fix it for 300?? WTF?! I told his *** it was ridiculous(cant spell lol)...and he wouldnt tell me what was wrong either...so do you guys know anything that would cost me 300$ thats connected to the heater problem?
Old Jan 18, 2007 | 06:37 PM
datsetup's Avatar
datsetup
ok good news i changed the hose and now i have HEAT!!!! ok so now whats wrong>> if i had to change the hose wat was the problem??
Old Jan 18, 2007 | 06:41 PM
Jewcano's Avatar
Jewcano
Check the small things first, see if you have enough coolant, blah blah, see if the hoses are in place, make sure the solenoid is working. There are tons of small things that dealers will screw you over with, and if he isnt telling you what it is, then most likely its something you can fix yourself really easily.
Old Jan 18, 2007 | 06:42 PM
Jewcano's Avatar
Jewcano
Maybe it had a hole in it that leaked? Did you replace it or just pull it and plug it back in?
Old Jan 21, 2007 | 02:10 PM
tommyt811's Avatar
tommyt811
Ok i swapped the hoses. Now i have heat.
Can i just leave it like that and run the car fine? Will it mess up anything? Dangerous in any way?? I live in san francisco, and the weather is always cold so i don't use the cold air that much.
So the heat works, is there a way to fix it so i can put my hoses back?
I heard it was the solenoid, but where can i get one? and where is it located??
Old Jan 21, 2007 | 04:25 PM
aliga's Avatar
aliga
Former Sponsor
fix it the right way with a working heater valve. i have one 55 shipped to your door.
streetnick
Mar 2, 2017 07:43 PM
Sid Ellner
Jun 8, 2009 02:41 PM
bigdogg49
GS - 1st Gen (1993-1997)
17
Dec 18, 2008 09:27 AM
CDY
Oct 24, 2008 12:14 PM
