2 Transmission questions
Old Jan 4, 2007 | 08:30 PM
GarrettSC's Avatar
GarrettSC
Default 2 Transmission questions
I searched but could not find the exact answers.
Question 1: My car has 165k on it and I am pretty sure the transmission has never been flushed, I work and Jiffy Lube (laugh all you want) and they say no more than 100k for automatics, are they wrong? Is it safe to do it?
Question 2: How does the PWR/ETC button work and what does it do to the transmission mechanicly?
Old Jan 5, 2007 | 07:22 AM
labmd's Avatar
labmd
Answer 2: With PWR on it makes your transmission shift later. If you hit the kickdown switch, it doesn't make a difference if PWR is on or not. But I'm not 100% sure of any of that.
Old Jan 5, 2007 | 08:11 AM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
be wary of flushing autos with higher mileage...
just drain and fill, make sure you use Amsoil or Toyota typet-iv
Old Jan 5, 2007 | 09:00 AM
Lexmex's Avatar
Lexmex
Amsoil ATF is excellent stuff...too bad I cannot get it down here or even import it without red tape.
With the PWR button on, my 1/4 mile times go a peak faster at least .1 to .150.
I would not flush the ATF. Instead, do 3 drain and fills over the course of 3 weeks. Flushing the ATF in the condition you described could 'shock' the tranny.
Old Jan 12, 2007 | 10:47 AM
labmd's Avatar
labmd
And you run with the OD off. Then maybe PWR does more for the car and/or your psyche. With OD off you can't get into 4th/OD, right?
According to my el cheapo service manual regarding the A340E transmission, I was wrong. The difference between kick-down with NORM verse kick-down with PWR is only (regarding shift points) from 3rd gear to OD, 106-110mph vs. 111-116mph. Bottom line: if you want to go fast, hit PWR. It can only help.
Old Jan 12, 2007 | 10:51 AM
sc250tt's Avatar
sc250tt
where can i get amsoil to buy
Old Jan 14, 2007 | 01:06 PM
AKauto's Avatar
AKauto
trany flushes are to be done every 30k, if you think the car has never had a flush done you can expect clogged valve bodies at the least
Old Jan 14, 2007 | 03:11 PM
Lexmex's Avatar
Lexmex
The highest gear I get into on my 1/4 mile runs are the 3rd, crossing the line roughly about 75 to 76 mph, keeping in mind that I am at high altitude. RX300 has some different ratios of course than other Lexus vehicles.
Amsoil's website www.amsoil.com lists distributors (though they have none down here. )
Old Jan 14, 2007 | 03:18 PM
mitsuguy's Avatar
mitsuguy
wow, re read your manual...
trans fluid drain and fill at 30 or 60k, no flush...
in fact, power flushing the trans is not listed as a recommended service in ANY owners manual I've ever seen...
Old Jan 15, 2007 | 12:47 AM
Blu92SC4's Avatar
Blu92SC4
I was looking at the amsoil website but I didn't know which one we could use for our cars.
For the Type IV at my local Lexus dealer they were quoting me about $8 per quart.
Old Jan 15, 2007 | 01:26 AM
$C300's Avatar
$C300
So Flushing the Trans isnt a good idea? Just drain and fill? Btw my tranns has got 222K on it
Old Jan 15, 2007 | 08:25 AM
mitsuguy's Avatar
mitsuguy
I honestly don't know why anyone would ever flush the trans... It's easier, cheaper, and gets the job done just by draining and filling it...
Old Jan 22, 2007 | 01:47 AM
stevechumo's Avatar
stevechumo
Why do you think flushing the tranny with high mileage will "shock" the tranny? I completely flushed my tranny at 135,000 miles and it ran a lot better than before. The tranny shifts a lot smoother and quicker than before. When I flushed it, the fluid smelled like overcooked BBQ. The person who helped me did the job was a 22 years of tranmission veteran and he totally recommeded this flush. I feel the same way, too. Now, my SC has 147,000 and it's still smooth and strong. I stronly recommend flushing the tranny, no matter how high mileage it is. It has no bad effect on the tranny whatsoever.
The ECT button will make the car a little faster, because it delays shifting. I've turned this ECT button on all the time.
Old Jan 22, 2007 | 07:37 AM
mitsuguy's Avatar
mitsuguy
You've obviously never seen a transmission fail shortly after a trans power flush... I have. High mileage transmissions don't always fare well with a trans power flush.
Just because it works for your car doesn't mean it will work for every car...
Until you've worked in the automotive maintenance industry, you need to make sure everyone knows that you are talking about "in your case"
here's a great post from the cadillac forums... read the whole thread:
http://www.cadillacforums.com/forums...ranny-52k.html
here's more:
http://www.cadillacforums.com/cadill...tml#transflush
and that only took 5 minutes of searching...
Old Jan 27, 2007 | 03:41 PM
stevechumo's Avatar
stevechumo
here's more:
Cadillac tranny can't be compared with this Lexus tranny. Not at all. Anyway, I respect your point, but I'd like to know the explanation why you think it'll cause the tranny to fail after the flush.
I've been working on cars, either building the engines or turbo systems for years.
