Anytime you replace your shocks, you should get your car realigned.
Please explain why. If there are no existing alignment issues, new shocks will not change the alignment. Sure, it can never hurt to have the car re-aligned, but a blanket statement of saying to do it seems overboard.
Thanks a lot for the advice! I will go with the KYB as I want to keep the car as close to stock as possible. One more question. What is the quality of the KYB compare to Tokico? By this I mean reliability.
correct... changing shocks on our vehicles does not require an alignment whatsoever...
so long as you aren't converting to supra shocks, or a lowering spring at the same time, there is absolutely no need for an alignment
I have had Tokico Blues on my 240 for the last 2 years and the ride is excellent even with an eibach prokit. KYB GR2s are nice but they don't like anything other then oem ride height springs or they will be blown in a year.
