HELP!: rear brake area noise
Old Dec 18, 2006 | 05:55 PM
RaynArt's Avatar
RaynArt
Default HELP!: rear brake area noise
yes i did search, maybe im bad at it. closest thing i found is this.
https://www.clublexus.com/forums/sho...ar+brake+noise
well im getting that wowowowowow noise from the rear. what side exactly i cant pinpoint. it sounds like a flat tire almost. this noise the on/off sound depending on the rate of speed. sounds almost like a flat tire. it gets louder the faster i go.
i dont feel any loss in braking power but i am getting a little bit of shaking under heavier braking at higher speeds.
so i changed the rear rotors/pads. no change.
switch back to 16 oem wheels. no change (normally on 17 supra wheels)
i had a caliper freeze up on me before and it never made a noise like this or even close. cant figure it out, any help is appreciated thanks.
my only guesses is something with the caliper or the e-brake?
Old Dec 18, 2006 | 06:11 PM
LexusFTW's Avatar
LexusFTW
wheel bearing...they tend to go out.
Old Dec 18, 2006 | 08:01 PM
96gti2.0t's Avatar
96gti2.0t
i would go with wheel bearing also
Old Dec 21, 2006 | 05:10 PM
RaynArt's Avatar
RaynArt
just got back from the shop. wheel bearings, brakes, etc are fine........ noise commin from the diff
ill let u know how it goes. but for now gonna have to borrow the gf's tC
Old Dec 21, 2006 | 06:58 PM
96gti2.0t's Avatar
96gti2.0t
theres a 97 sc in the junkyard here that had the diff last time i went not even leaking wonder if tis still there
simpson227
Aug 10, 2018 12:44 PM
tm8747a
Jul 19, 2014 12:03 PM
calichris
Sep 5, 2007 06:45 PM
cal_alum98
Suspension and Brakes
Jun 16, 2006 05:50 AM
riverdale
Dec 4, 2005 04:58 PM
