Power steering pump overflow
Old Dec 15, 2006 | 11:08 AM
JohnEd's Avatar
JohnEd
Default Power steering pump overflow
Guys,
Saw this thread a short while back where the pump fluid would foam up and overflow. Six or eight posts and everybody was amazed. NMe too for the past week until I had my A PIFF ANY. The planned fix was to rebuild the pump with a $54 kit. I think I figured out the problem. Background: The foaming indicates that air is getting into the system prior to the oil going through the pump. The entire system is under positive pressure except for the resevoir and one small "point". This is to say that if there is a hole in the system the thing will leak fluid out....not injest air. Except for that "point", which is the input OR-FUSS on the pump which is burried inside the pump housing. And right at that point there is some serious suck. That point is driven by and is part of the drive shaft/pulley. The drive shaft seal is worn out and letting air be sucked into the innards of the pump. I'll bet that seal has a generac equal item that cost less than $10.
Happy Holidays
John
Old Dec 15, 2006 | 12:04 PM
salimshah's Avatar
salimshah
25 Year Member
In my case, it was hard to pinpoint where the air was coming in. I replaced the pump with some reservations and fortunately it cured the problem.
I did not purchase the service kit, but keep in mind, the vanes are not part of the kit. During overhaul, one should mesure and replace the vanes if needed.
Wish you luck and I hope the overhaul cures your problem too. Remeber to purchase the banjo compression washer. Let me know if you figure out how to torqe the banjo bolt. Let alone torque wrench, I could not even get the socket on it.
Salim
Dx3
Jun 25, 2014 11:47 AM
worldforgo
Feb 4, 2012 09:47 PM
whattaGS
GS - 1st Gen (1993-1997)
Sep 5, 2011 03:34 AM
dubstar
IS - 1st Gen (2001-2005)
Jun 17, 2011 04:29 PM
Herm
Maintenance
22
May 6, 2011 02:16 PM
