1jz downpie ?
Old Dec 8, 2006 | 02:44 PM
JohnnyB822's Avatar
JohnnyB822
Default 1jz downpie ?
i know a 2jz downpipe will work with a 1jz but with customizing it. but i was wondering what do you have to do to make it fit the stock twins on a 1jz? or would it be better if you just used a dp from a mkIII 1jz
Old Dec 8, 2006 | 02:57 PM
Answer300's Avatar
Answer300
just buy the one thats offered through Greddy. thats the one i got
Old Dec 8, 2006 | 03:04 PM
JohnnyB822's Avatar
JohnnyB822
where did you find it. ive looked and can't find it could you maybe send me a link
Old Dec 8, 2006 | 03:09 PM
Answer300's Avatar
Answer300
i can give you the place and number where i got mine from.
Project Nissan
Garland, TX 75041
214-703-0398
** ask to speak to Robert or Anthony **
tell them Tommy sent cha'!
Old Dec 8, 2006 | 05:57 PM
Notorious's Avatar
Notorious
post a link? always interested in 1JZ mods... haven't been able to find a DP either...
Old Dec 8, 2006 | 10:40 PM
JohnnyB822's Avatar
JohnnyB822
still would like to know what it takes to make a aftermarket MKIV dp fit a 1JZ SC
Old Dec 9, 2006 | 05:24 AM
blaznsc4's Avatar
blaznsc4
what about replacing the y-pipe? does greddy offer one?
Old Dec 9, 2006 | 02:09 PM
JohnnyB822's Avatar
JohnnyB822
well i have answered my question a little bit i found a dp from hks japan for a soarer and it has the same part# as a supra, so i called HKS america to ask and see if they could help a little bit and they said that they are the same part. They aren't definitly sure it will fit but think it may. so if you hgave any feedback on weather i am wrong or not please let me know.
here is a link
http://www.hks-power.co.jp/products/...p/fp_data.html
Old Dec 10, 2006 | 11:18 PM
jgdynamics's Avatar
jgdynamics
yo dude, thats for a front pipe... yea they would be the same... are you guys looking for a DP that bolts to the stock twins?
Old Dec 11, 2006 | 01:31 PM
Answer300's Avatar
Answer300
Default heres a link!
projectnissan.com
they specialize in nissan jdm and oem aftermarket enhancements but they get any and everything for the Soarer based upon request.
Old Dec 11, 2006 | 05:44 PM
got_trd's Avatar
got_trd
So Johnny, did you pic up rics green car? Im still interested in your red one so let me know....
Right before i blew my motor I was going to buy a downpipe from my friend who had it on his mkiii supra (1jz). I looked at the dp in person and it'll fit but will probably have to be shortened to bolt up to the stock sc exhaust... I can still get you the downpipe if you want to play with it. It has the 3 bolt flange off the twins and the right angles down to where it would have to be shortened to bolt up to our car so ytea...
Old Dec 11, 2006 | 06:42 PM
drnkcarlos's Avatar
drnkcarlos
The piece between the supra and SC/Soarers that is the same is the front pipe(straight pipe), the part off the turbines is different between soarer and supra. the supra part connect to each turbine if I recall correctly.
Anyways if your looking for some parts the Apexi parts are nice.
The turbine side piece has a flex pipe and the straight pipe has no bung for the sensor to go into, so just a heads up.
Here are the Apexi part numbers for soarer
Turbine side: 145-T003 (75mm->80mm) different part number than supra (supra uses 145-T001)
Straight Pipe: 145-T005(80mm) (same part number as Supra)
Old Dec 12, 2006 | 02:32 AM
jgdynamics's Avatar
jgdynamics
yea, u can check out driftmotion.com
they offer the hks front pipe... i also talk to them, and they said they dont really recommend changing the DP off hte turbo... not really needed,, opening the front pipe helps alot more in making low end and top end... etc...
im prolly gonna place an order for the soarer front pipe and eliminate the second cat...
Old Dec 12, 2006 | 02:28 PM
JohnnyB822's Avatar
JohnnyB822
yea i got rics car yesterday, but i think i will look at your friends DP, but i wont have stock exhaust for to much longer i will switch all of my stuff over soon just give me a call or something so i can see it
and i will let you know when my red car is for sale
Old Dec 12, 2006 | 03:34 PM
V300Altus's Avatar
V300Altus
https://935motorsports.com/catalog/p...oducts_id=1018
This is the Y-pipe.
