removed pre-cats?
Old Nov 24, 2006 | 08:01 PM
sean9975's Avatar
sean9975
Default removed pre-cats?
has anyone tried to remove pre-cats, manifold staight 2 high flo cat ,"y" fitting staight 2 mufflers on sc 400?
Old Nov 24, 2006 | 09:24 PM
Lucky SC's Avatar
Lucky SC
yea i think so
some guy deleted all but center one and put in an "x" pipe there all custom 3" piping
3" w/o a turbo though doesn't sound good
HE SAID it turned out good, i didnt get any specific stat changes
Lucky SC's Avatar
Lucky SC
i'm sure Y would work though btw
Old Nov 25, 2006 | 10:49 AM
jibbby's Avatar
jibbby
Banned - could not follow forum rules
I have, what do you want to know?...I deleting the precats and I also used the magnaflow 2 into 1 center cat with the built in high flowing Y design...Good improvement in power was noticed at higher rpms from both changes......Deleting all cats and installing a highflowing X design would be the best option for performance, but say goodbye to passing smog emissions...
Old Nov 25, 2006 | 06:17 PM
sean9975's Avatar
sean9975
see that's the only thing. it wont pass emissions? that sucks is threr a way around that? or do you have to have the pre-cats to pass?
Old Nov 25, 2006 | 08:15 PM
jibbby's Avatar
jibbby
Well you can ditch the pre-cats and install two single high flowing cats and locate them else where on the exhaust system..Custom down pipes will need to be fabed..It maybe hard to find exact fitting replacements...Search I think I read somewhere about replacement high flowing precats from Magna flow......
I do know you need all three to pass emission here in California where I live..The one main high flowing center cat is not enough to pass......
Old Nov 25, 2006 | 10:19 PM
sean9975's Avatar
sean9975
how much did those headers set u back?
Old Nov 26, 2006 | 11:13 AM
jibbby's Avatar
jibbby
Too much...$700 for the S&S Headers, $400 for the prefabed down pipes, $300 for entire intallation.....$1300 total for the headers installed and alot of fitting headaches.... If I were to do it all over again I would have paid $900 for the EKtuning.com headers...Atleast they are a direct bolt on header as apposed to the S&S's.....
tenac2215
Apr 13, 2013 06:14 AM
dallasbean
North Texas Lexus Club
Mar 15, 2009 07:15 AM
caleb11210
Mar 7, 2008 02:17 PM
nysupraman
Jun 29, 2005 01:12 AM
imbuggin
Feb 27, 2005 10:17 PM
